Infos on connection pooling
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Mar 17 11:44:16 EST 2006
Is there any documentation on the way connection pooling works in
MapServer? I did a search on the website and found only two references:
A section of the OGR HOWTO:
http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#connection-pooling
and a paragraph under the PROCESSING directive in the mapfile/layer docs:
http://mapserver.gis.umn.edu/docs/reference/mapfile/layer/?searchterm=connection%20pooling
Is the information in the OGR howto the most complete doc that we have
for this feature?
Also, the LAYER docs says that Oracle connections support pooling. Is
this support complete? Are there any known issues with using connection
pooling with Oracle layers?
Thanks
Daniel
Daniel Morissette
http://www.mapgears.com/
