Today's CVS,
labels that follow street segments and antialias lines
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 21 14:35:24 EST 2006
There haven't been any recent changes that I know of that would
cause problems along these lines.
1a) Benj's last patch was applied several weeks ago as mentioned in comment #31 of bug 1620.
1b) I'm running brand new CVS code here and MINDISTANCE is working as usual
2) Paul's right, the most naive style would be:
STYLE
COLOR 170 153 34
WIDTH 5
ANTIALIAS TRUE
END
3) I'll work up a test case for you. What should work is setting 2 styles: 1 for the fill and the second
for the outline. E.g.:
STYLE COLOR 255 0 0 END
STYLE
COLOR 170 153 34
WIDTH 5
ANTIALIAS TRUE
END
Steve
>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/21/2006 12:39:50 PM >>>
Steve,
re 1) the latest cvs had working labels following lines (more or
less) when I last did it. I didn't check mindistance though. And
there are still some outstanding issues I think (unless this is the
un-committed patch?)
re 2) you need to change SYMBOL "circle" to SYMBOL 0, SIZE 3 to WIDTH
3 and set TRANSPARENCY ALPHA at the LAYER level.
re 3) I'd like to know the same thing. I never got polygons working :(
Cheers
Paul
On 21-Mar-06, at 1:21 PM, Stephen Woodbridge wrote:
> Hi all,
> I grabbed today CVS and I'm testing it with ka-map. I have a couple
> questions/issues:
> 1) labels that follow street segments
> a) Benj has a patch that need to get integrated when ever he is
> ready
> I didn't get it built into my test version yet.
> b) MINDISTANCE on labels is not working
> 2) Fuzzy brushes / antialiasing does not seem to be working. I'm
> using png output and the mapfile fragment looks like:
> CLASS
> NAME "Interstate Highways"
> EXPRESSION "1"
> STYLE
> SYMBOL "circle"
> COLOR 170 153 34
> SIZE 5
> ANTIALIAS TRUE
> END
> STYLE
> SYMBOL "circle"
> COLOR 238 187 34
> SIZE 3
> ANTIALIAS TRUE
> END
> END
> 3) How should I define a polygon layer so I can fill the polygon
> and outline it with antialiased?
> Thanks,
> -Steve W
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
