Today's CVS,
labels that follow street segments and antialias lines
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Mar 21 14:55:14 EST 2006
Steve Lime wrote:
> There haven't been any recent changes that I know of that would
> cause problems along these lines.
> 1a) Benj's last patch was applied several weeks ago as mentioned in comment #31 of bug 1620.
> 1b) I'm running brand new CVS code here and MINDISTANCE is working as usual
> 2) Paul's right, the most naive style would be:
> STYLE
> COLOR 170 153 34
> WIDTH 5
> ANTIALIAS TRUE
> END
OK, changing the mapfile to look like this, but reading the threads on
this I thought you could use SYMBOL "circle" with SIZE n also.
How to I get dashed AA lines?
Thanks,
-Steve W
> 3) I'll work up a test case for you. What should work is setting 2 styles: 1 for the fill and the second
> for the outline. E.g.:
> STYLE COLOR 255 0 0 END
> STYLE
> COLOR 170 153 34
> WIDTH 5
> ANTIALIAS TRUE
> END
> Steve
>>>>Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/21/2006 12:39:50 PM >>>
> Steve,
> re 1) the latest cvs had working labels following lines (more or
> less) when I last did it. I didn't check mindistance though. And
> there are still some outstanding issues I think (unless this is the
> un-committed patch?)
> re 2) you need to change SYMBOL "circle" to SYMBOL 0, SIZE 3 to WIDTH
> 3 and set TRANSPARENCY ALPHA at the LAYER level.
> re 3) I'd like to know the same thing. I never got polygons working :(
> Cheers
> Paul
> On 21-Mar-06, at 1:21 PM, Stephen Woodbridge wrote:
>>Hi all,
>>I grabbed today CVS and I'm testing it with ka-map. I have a couple
>>questions/issues:
>>1) labels that follow street segments
>> a) Benj has a patch that need to get integrated when ever he is
>>ready
>> I didn't get it built into my test version yet.
>> b) MINDISTANCE on labels is not working
>>2) Fuzzy brushes / antialiasing does not seem to be working. I'm
>>using png output and the mapfile fragment looks like:
>> CLASS
>> NAME "Interstate Highways"
>> EXPRESSION "1"
>> STYLE
>> SYMBOL "circle"
>> COLOR 170 153 34
>> SIZE 5
>> ANTIALIAS TRUE
>> END
>> STYLE
>> SYMBOL "circle"
>> COLOR 238 187 34
>> SIZE 3
>> ANTIALIAS TRUE
>> END
>> END
>>3) How should I define a polygon layer so I can fill the polygon
>>and outline it with antialiased?
>>Thanks,
>> -Steve W
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
