Width? (Re: Today's CVS,
labels that follow street segments and antialias lines)
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 21 16:19:16 EST 2006
Strictly speaking SIZE controls the y dimension of a tile or a brush used for
a fill or line drawing. It has no meaning without a symbol that can be scaled
somehow. WIDTH refers to the width of simple lines- lines drawn without the
aid of a symbol definition (or with a TYPE SIMPLE definition like the one below).
It is these simple lines that can be antialiased... I chose this for mainly for
consistency. We could make the typical
SYMBOL 'circle'
SIZE '10'
ANTIALIAS TRUE
produce an antialiased line easy enough, but using a square (TYPE VECTOR)
symbol instead of an ellipse would not result in antialiasing.
Steve
>>> Sean Gillies <sgillies at FRII.COM> 3/21/2006 3:00:10 PM >>>
Steve,
Line width used to be controlled by the "size" parameter. Has it
changed to being controlled by "width"?
Sean
On Mar 21, 2006, at 1:13 PM, Steve Lime wrote:
> I believe you create a symbol like this:
> SYMBOL
> TYPE SIMPLE
> NAME 'dash_10_on_10_off'
> STYLE '10 10'
> END
> STYLE
> SYMBOL 'dash_10_on_10_off'
> COLOR 170 153 34
> WIDTH 5
> ANTIALIAS TRUE
> END
> Steve
>>>> Stephen Woodbridge <woodbri at swoodbridge.com> 3/21/2006 1:55:14
>>>> PM >>>
> Steve Lime wrote:
>> There haven't been any recent changes that I know of that would
>> cause problems along these lines.
>> =20
>> 1a) Benj's last patch was applied several weeks ago as mentioned in =
> comment #31 of bug 1620.
>> 1b) I'm running brand new CVS code here and MINDISTANCE is working
>> as =
> usual
>> =20
>> 2) Paul's right, the most naive style would be:
>> =20
>> STYLE
>> COLOR 170 153 34
>> WIDTH 5
>> ANTIALIAS TRUE
>> END
> OK, changing the mapfile to look like this, but reading the threads
> on=20
> this I thought you could use SYMBOL "circle" with SIZE n also.
> How to I get dashed AA lines?
> Thanks,
> -Steve W
>> 3) I'll work up a test case for you. What should work is setting 2 =
> styles: 1 for the fill and the second
>> for the outline. E.g.:
>> =20
>> STYLE COLOR 255 0 0 END
>> STYLE
>> COLOR 170 153 34
>> WIDTH 5
>> ANTIALIAS TRUE
>> END
>> =20
>> Steve
>> =20
>> =20
>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/21/2006 12:39:50 PM >>>
>> =20
>> Steve,
>> =20
>> re 1) the latest cvs had working labels following lines (more or =20
>> less) when I last did it. I didn't check mindistance though. And
>> =20
>> there are still some outstanding issues I think (unless this is
>> the =20
>> un-committed patch?)
>> =20
>> re 2) you need to change SYMBOL "circle" to SYMBOL 0, SIZE 3 to
>> WIDTH =
> =20
>> 3 and set TRANSPARENCY ALPHA at the LAYER level.
>> =20
>> re 3) I'd like to know the same thing. I never got polygons
>> working :(
>> =20
>> Cheers
>> =20
>> Paul
>> =20
>> =20
>> =20
>> On 21-Mar-06, at 1:21 PM, Stephen Woodbridge wrote:
>> =20
>> =20
>>> Hi all,
>>> I grabbed today CVS and I'm testing it with ka-map. I have a
>>> couple =20
>>> questions/issues:
>>> 1) labels that follow street segments
>>> a) Benj has a patch that need to get integrated when ever he is
>>> =20
>>> ready
>>> I didn't get it built into my test version yet.
>>> b) MINDISTANCE on labels is not working
>>> 2) Fuzzy brushes / antialiasing does not seem to be working. I'm =20
>>> using png output and the mapfile fragment looks like:
>>> CLASS
>>> NAME "Interstate Highways"
>>> EXPRESSION "1"
>>> STYLE
>>> SYMBOL "circle"
>>> COLOR 170 153 34
>>> SIZE 5
>>> ANTIALIAS TRUE
>>> END
>>> STYLE
>>> SYMBOL "circle"
>>> COLOR 238 187 34
>>> SIZE 3
>>> ANTIALIAS TRUE
>>> END
>>> END
>>> 3) How should I define a polygon layer so I can fill the polygon =20
>>> and outline it with antialiased?
>>> Thanks,
>>> -Steve W
>> =20
>> =20
>> |Paul Spencer pspencer at dmsolutions.ca |
>> |Applications & Software Development |
>> |DM Solutions Group Inc http://www.dmsolutions.ca/|
>> =20
>> =20
