Today's CVS, labels that follow street segments and antialias lines
Steve Lime steve.lime at DNR.STATE.MN.US
Tue Mar 21 16:22:34 EST 2006
Will have to check the source (and Benj) on the MINDISTANCE and
labels that follow segments. Our integration plan was to certainly allow
for that to work but I'd have to go back to the source to see if the
check is being bypassed somehow.
Steve
>>> Stephen Woodbridge <woodbri at SWOODBRIDGE.COM> 3/21/2006 2:23:16 PM >>>
Also added TRANSPARENCY ALPHA to the LAYER, but still not AA.
Do I need to define a special output format?
Also MINDISTANCE does not seem to be working with ANGLE FOLLOW.
I will recheck everything on this end and make sure everything is built
corectly.
-Steve W
Stephen Woodbridge wrote:
> Steve Lime wrote:
>> There haven't been any recent changes that I know of that would
>> cause problems along these lines.
>> 1a) Benj's last patch was applied several weeks ago as mentioned in
>> comment #31 of bug 1620.
>> 1b) I'm running brand new CVS code here and MINDISTANCE is working as
>> usual
>> 2) Paul's right, the most naive style would be:
>>        STYLE
>>          COLOR 170 153 34
>>          WIDTH 5
>>          ANTIALIAS TRUE
>>        END
> OK, changing the mapfile to look like this, but reading the threads on
> this I thought you could use SYMBOL "circle" with SIZE n also.
> How to I get dashed AA lines?
> Thanks,
>   -Steve W
>> 3) I'll work up a test case for you. What should work is setting 2
>> styles: 1 for the fill and the second
>> for the outline. E.g.:
>> STYLE COLOR 255 0 0 END
>> STYLE
>>    COLOR 170 153 34
>>    WIDTH 5
>>    ANTIALIAS TRUE
>> END
>> Steve
>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/21/2006 12:39:50 PM >>>
>> Steve,
>> re 1) the latest cvs had working labels following lines (more or
>> less) when I last did it.  I didn't check mindistance though.  And
>> there are still some outstanding issues I think (unless this is the
>> un-committed patch?)
>> re 2) you need to change SYMBOL "circle" to SYMBOL 0, SIZE 3 to WIDTH
>> 3 and set TRANSPARENCY ALPHA at the LAYER level.
>> re 3) I'd like to know the same thing.  I never got polygons working :(
>> Cheers
>> Paul
>> On 21-Mar-06, at 1:21 PM, Stephen Woodbridge wrote:
>>> Hi all,
>>> I grabbed today CVS and I'm testing it with ka-map. I have a couple
>>> questions/issues:
>>> 1) labels that follow street segments
>>>   a) Benj has a patch that need to get integrated when ever he is  ready
>>>      I didn't get it built into my test version yet.
>>>   b) MINDISTANCE on labels is not working
>>> 2) Fuzzy brushes / antialiasing does not seem to be working. I'm
>>> using png output and the mapfile fragment looks like:
>>>    CLASS
>>>      NAME "Interstate Highways"
>>>      EXPRESSION "1"
>>>      STYLE
>>>        SYMBOL "circle"
>>>        COLOR 170 153 34
>>>        SIZE 5
>>>        ANTIALIAS TRUE
>>>      END
>>>      STYLE
>>>        SYMBOL "circle"
>>>        COLOR 238 187 34
>>>        SIZE 3
>>>        ANTIALIAS TRUE
>>>      END
>>>    END
>>> 3) How should I define a polygon layer so I can fill the polygon  and
>>> outline it with antialiased?
>>> Thanks,
>>>  -Steve W
>> |Paul Spencer                           pspencer at dmsolutions.ca   |
>> |Applications & Software Development                              |
>> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
