Automated tests (was Call for 4.8.3 release...)
Howard Butler
hobu at IASTATE.EDU
Mon Mar 27 18:32:55 EST 2006
Actually, I ran the python test suite on windows before blessing the
4.8.2 release, but for some reason the bug didn't manifest
itself. Only when I started working on the buildbot
<http://mapserver.builds.hobu.net> did it show up.
The postgis that Paul Moen pointed out that missed 4.8.2 is described
here <http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1629>.
Howard
At 05:26 PM 3/27/2006, Steve Lime wrote:
>This brings us to another point. Sean's tests identified the
>embedding problem but were not run by me (or anyone else as far as I
>know) prior to the 4.8.2 release. In fact that bug probably was
>there at the 4.8.0 release. Others (Sean, Umberto and so on) have
>pushed for more testing and this issue underscores the fact.
>However, IMHO the tests need to be part of the "build" process so a
>make test and/or make pytest could trigger things very easily.
>This is a hot topic on the OSGeo incubator list. How should we
>proceed as a project?
>Steve
> >>> Frank Warmerdam <warmerdam at POBOX.COM> 03/27/06 2:56 PM >>>
>Steve Lime wrote:
> > Hi all: We fixed a somewhat obscure but nasty bug with embeded
> legends and scalebars over the weekend. Basically you can't use
> that feature in 4.8 at all. It might make sense to cut a 4.8.3 to
> mitigate the problem. Looks like there was also a PostGIS patch
> that wasn't applied to 4.8.2. Any objections?
> > Steve
>Steve,
>Please! With all speed!
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | President OSGF, http://osgeo.org
