RFC 17: Dynamic Array Sizing
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sat May 13 02:42:47 EDT 2006
Frank,
have you considered using apr (Apache Portable Runtime)? It does this
and many other things (including connection pooling) and apache
(albeit this is part apache2) is already a requirement for mapserver.
I will also check to see if they have atof or similar functions so
that (maybe?) we can solve tamas' issue with locales.
I will dig out a couple of howtos from my rss feeds and send you the links asap.
The home page for apr is at: apr.apache.org.
Best regards,
Umberto
On 5/12/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Folks,
> There was yet another request for a mapserver compiled with larger
> sizes for one of the MS_MAX* macros on #mapserver today, and it drove
> me over the edge! I flipped out!
> The result is RFC 17. I propose to spend a day overhauling MapServer
> to use dynamic sizing for all the important "limits" (symbols, layers,
> classes and styles).
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-17
> While it is open to discussion and ammendment, I'll accept votes even now.
> I won't actually implement it till after I'm done the RFC 16 work.
> I'm going RFC crazy!
> I furthermore unofficially propose the next version be called
> MapServer 5.0, code named "Dynamic Dodger" in honour of the alliterative
> Ubuntu code names (ie. Breezy Badger, Dapper Duck).
> Best regards
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
