RFC 17: Dynamic Array Sizing
Frank Warmerdam
warmerdam at POBOX.COM
Mon May 15 08:59:03 EDT 2006
Tamas Szekeres wrote:
> Frank,
> 2006/5/15, Frank Warmerdam <warmerdam at pobox.com>:
>> > Is it possible to add the new items automatically on demand?
>> I think that is what I'm proposing! In what sense do you mean?
> I have mentioned to eliminate the following issues from the code, like:
> mapfile.c (4663)
> case(LAYER):
> if(map->numlayers == MS_MAXLAYERS) {
> msSetError(MS_IDENTERR, "Maximum number of layers reached.",
> "msLoadMap()");
> return(NULL);
> When the program needs more items of a particular time it should
> allocate it automatically. I couldn't read this from the RFC, but it
> may be there and i have missed it.
Tamas,
That was intended to be indicated by this entry:
* mapfile.c: set maxlayers to MS_MAXLAYERS and allocate layers accordingly in
initMap(). Use msGrowMapLayers() before calling initLayer() when parsing.
So, the above code would become.
case (LAYER):
msGrowMapLayers( map );
The msGrowMapLayers() would be responsible for ensuring that there is
*at least* one available unused layer object in the layers array.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
