RFC 17: Dynamic Array Sizing
Frank Warmerdam
warmerdam at POBOX.COM
Mon May 15 08:53:40 EDT 2006
Benedikt Rothe wrote:
> Hi
> Sorry for posting in this list since I'm no mapserver-developer, but I
> wonder wether RFC17 may break
> mapscript-applications, which hold pointers to mapserver-Objects.
> Example Java:
> - A Java-layerObj is created with "aMapObject.getlayer(1)". This
> layerObj-instance holds a pointer
> into the Layer-Array of the aMapObject.
> - After this, a new layer is added to the webobject. The layers-Array
> in the webObject could be reallocated
> by this action.
> - Therfore the existing pointer in the Java-layerObj could become invalid.
> This could cause crashes.
> Did I oversee something?
> Benedikt
Benedikt,
Yikes, you are quite right. In fact whenever we actually end up "growing"
the list of layers, classes or styles any old pointers could be invalidated.
I don't forsee this occuring too often in the mapserver core itself because
it isn't common to keep pointers around. Instead it is layer/class/style
indexes that are normally kept over time.
In other C/C++ contexts I would normally have my layers array as an array of
pointers to individually allocated layerObj's. That way, reallocating the
array of pointers would not cause the existing layerObj's to move. But
because mapserver uses a direct array of layerObj's, reallocating inevitably
means the need to move all the existing layers in memory (and similarly for
other objects).
I *suppose* we could move to individual allocations in mapserver as well.
But I think this would cause a lot of changes in the code that would make
the effort much bigger, as well as resulting in more memory fragmentation.
There are lots of places in the code that do stuff like this:
lp = &(map->layers[ map->layerorder[i]]);
If we changed layers to be an array of layerObj pointers, this would return
a pointer to the layerObj pointer, instead of the pointer to the layerObj
itself. So quite a bit of code would need to be touched. This change,
within the mapserver core, should be relatively routine grunt work. I'm not
sure if it would have a significant affect on mapscript or not. I *think*
this change would be relatively invisible to mapscript once re-swigged and
rebuilt.
I think I would be willing to try and implement individual allocation of
the layer/class/style objects if the developer would like to take this
approach. The downside is that there is likely to be changes required in
parts of MapServer I don't normally build (like specific data providers
and specific output drivers). There is also likely to be more work required
in the swig bindings. Should I rewrite the RFC with this intent?
To be clear, most of the RFC would remain the same, but something like:
layerObj *layers;
int numlayers; /* number of layers in mapfile */
int maxlayers;
would become:
layerObj **layers;
int maxlayers;
So "layers" is a pointer to an array of layerObj pointers. When the map is
initialized each of the initial MS_MAXLAYERS layerObj would be individually
malloced, and initialized. when the msGrowMapLayers() function needs to
grow the layers list it would reallocate the array of pointers larger,
and allocate some new layerObj's.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
