A MapServer 5.0 Branch? (Re: RFC 17: Dynamic Array Sizing)
Sean Gillies
sgillies at FRII.COM
Mon May 15 10:44:35 EDT 2006
On May 15, 2006, at 6:53 AM, Frank Warmerdam wrote:
> Benedikt Rothe wrote:
>> Hi
>> Sorry for posting in this list since I'm no mapserver-developer,
>> but I
>> wonder wether RFC17 may break
>> mapscript-applications, which hold pointers to mapserver-Objects.
>> Example Java:
>> - A Java-layerObj is created with "aMapObject.getlayer(1)". This
>> layerObj-instance holds a pointer
>> into the Layer-Array of the aMapObject.
>> - After this, a new layer is added to the webobject. The layers-
>> Array
>> in the webObject could be reallocated
>> by this action.
>> - Therfore the existing pointer in the Java-layerObj could become
>> invalid.
>> This could cause crashes.
>> Did I oversee something?
>> Benedikt
> Benedikt,
> Yikes, you are quite right. In fact whenever we actually end up
> "growing"
> the list of layers, classes or styles any old pointers could be
> invalidated.
> I don't forsee this occuring too often in the mapserver core itself
> because
> it isn't common to keep pointers around. Instead it is layer/class/
> style
> indexes that are normally kept over time.
> In other C/C++ contexts I would normally have my layers array as an
> array of
> pointers to individually allocated layerObj's. That way,
> reallocating the
> array of pointers would not cause the existing layerObj's to move.
> But
> because mapserver uses a direct array of layerObj's, reallocating
> inevitably
> means the need to move all the existing layers in memory (and
> similarly for
> other objects).
> I *suppose* we could move to individual allocations in mapserver as
> well.
> But I think this would cause a lot of changes in the code that
> would make
> the effort much bigger, as well as resulting in more memory
> fragmentation.
> There are lots of places in the code that do stuff like this:
> lp = &(map->layers[ map->layerorder[i]]);
> If we changed layers to be an array of layerObj pointers, this
> would return
> a pointer to the layerObj pointer, instead of the pointer to the
> layerObj
> itself. So quite a bit of code would need to be touched. This
> change,
> within the mapserver core, should be relatively routine grunt
> work. I'm not
> sure if it would have a significant affect on mapscript or not. I
> *think*
> this change would be relatively invisible to mapscript once re-
> swigged and
> rebuilt.
> I think I would be willing to try and implement individual
> allocation of
> the layer/class/style objects if the developer would like to take this
> approach. The downside is that there is likely to be changes
> required in
> parts of MapServer I don't normally build (like specific data
> providers
> and specific output drivers). There is also likely to be more work
> required
> in the swig bindings. Should I rewrite the RFC with this intent?
Maybe this work could be done in a new branch and we could take
advantage of the opportunity to ditch some unsupported or outdated
aspects of MapServer: non-OGR mysql, image maps, flash, cartoline.
It's funny that I made a very similar proposal about 2 years ago, but
the response from other developers at the time was "YAGNI".
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?
RefactoringObjectCollections
Frank, count on me for help with testing the effects on Python
mapscript.
Sean
Sean Gillies
http://zcologia.com
