RFC 17: Dynamic Array Sizing
Benedikt Rothe umn-ms at HYDROTEC.DE
Mon May 15 10:38:35 EDT 2006
Frank,
My impression is, that PHP-Mapscript will face the mentioned problem also.
And problably every swig-based Mapscript will have it. I had a look on
Python-Mapscript.
I think for the sake of "backward compatibility" the problem should be
solved somehow. (For shure
"individual allocation" would be a solution ...)
Benedikt
UMN MapServer Developers List <MAPSERVER-DEV at LISTS.UMN.EDU> schrieb am
15.05.2006 14:53:40:
> Benedikt Rothe wrote:
> > Hi
> > Sorry for posting in this list since I'm no mapserver-developer, but I
> > wonder wether RFC17 may break
> > mapscript-applications, which hold pointers to mapserver-Objects.
> > Example Java:
> > - A Java-layerObj is created with "aMapObject.getlayer(1)". This
> > layerObj-instance holds a pointer
> >   into the Layer-Array of the aMapObject.
> > - After this, a new layer is added to the webobject.  The layers-Array
> > in the webObject could be reallocated
> >   by this action.
> > - Therfore the existing pointer in the Java-layerObj could become
invalid.
> > This could cause crashes.
> > Did I oversee something?
> > Benedikt
> Benedikt,
> Yikes, you are quite right.  In fact whenever we actually end up
"growing"
> the list of layers, classes or styles any old pointers could be
invalidated.
> I don't forsee this occuring too often in the mapserver core itself
because
> it isn't common to keep pointers around.  Instead it is
layer/class/style
> indexes that are normally kept over time.
> In other C/C++ contexts I would normally have my layers array as an
array of
> pointers to individually allocated layerObj's.  That way, reallocating
the
> array of pointers would not cause the existing layerObj's to move.  But
> because mapserver uses a direct array of layerObj's, reallocating
inevitably
> means the need to move all the existing layers in memory (and similarly
for
> other objects).
> I *suppose* we could move to individual allocations in mapserver as
well.
> But I think this would cause a lot of changes in the code that would
make
> the effort much bigger, as well as resulting in more memory
fragmentation.
> There are lots of places in the code that do stuff like this:
>          lp = &(map->layers[ map->layerorder[i]]);
> If we changed layers to be an array of layerObj pointers, this would
return
> a pointer to the layerObj pointer, instead of the pointer to the
layerObj
> itself.  So quite a bit of code would need to be touched.   This change,
> within the mapserver core, should be relatively routine grunt work.  I'm
not
> sure if it would have a significant affect on mapscript or not.  I
*think*
> this change would be relatively invisible to mapscript once re-swigged
and
> rebuilt.
> I think I would be willing to try and implement individual allocation of
> the layer/class/style objects if the developer would like to take this
> approach.  The downside is that there is likely to be changes required
in
> parts of MapServer I don't normally build (like specific data providers
> and specific output drivers).  There is also likely to be more work
required
> in the swig bindings.  Should I rewrite the RFC with this intent?
> To be clear, most of the RFC would remain the same, but something like:
>    layerObj *layers;
>    int numlayers; /* number of layers in mapfile */
>    int maxlayers;
> would become:
>    layerObj **layers;
>    int maxlayers;
> So "layers" is a pointer to an array of layerObj pointers.  When the map
is
> initialized each of the initial MS_MAXLAYERS layerObj would be
individually
> malloced, and initialized.  when the msGrowMapLayers() function needs to
> grow the layers list it would reallocate the array of pointers larger,
> and allocate some new layerObj's.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF,
http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060515/20110c04/attachment.html
