RFC 17: Dynamic Array Sizing
Sean Gillies
sgillies at FRII.COM
Mon May 15 16:39:59 EDT 2006
On May 15, 2006, at 1:28 PM, Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> Ned Harding wrote:
>>>> layerObj **layers;
>>>> int numlayers; /* number of layers in mapfile */
>>>> int maxlayers;
>>> Hey Frank,
>>> One request... If you are going to change the meaning of the var
>>> layers
>>> or other similar vars, can you change the name? ppLayers or
>>> something,
>>> frankly anything, so its made obvious to other code that links
>>> with it?
>> Ned,
>> Currently SWIG generated bindings allow script to access a layer as
>> map->layers[0].name. This would continue to work even if the layers
>> became an array of pointers. So I changing the name of layers would
>> essentially break all existing mapscript applications and for that
>> reason
>> I think this change is a non-starter.
> I would tend to agree with Ned that changing the meaning of a variable
> in a data structure without changing its name is asking for trouble.
> PHP MapScript never accesses layers, classes and styles by index
> directly, you must go through a get() method all the time. Doesn't
> SWIG
> MapScript have the same get() methods? Could we not hide the arrays
> and
> enforce the use of get() methods?
Daniel,
You're right, it's getLayer(index), getClass(index), etc. You can't
directly access layers in the SWIG-generated modules unless this is a
new feature. I got off the SWIG bandwagon around 1.3.26, so I don't
know for sure.
>> I would add we aren't in the habit of using hungarian style
>> prefixes in
>> mapserver and I'm not that keen on introducing them widely.
> Agreed.
Yay.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
Sean Gillies
http://zcologia.com
