[Fwd: Re: [UMN_MAPSERVER-DEV] New bug owner for mapscript needed]
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Mon May 29 12:40:06 EDT 2006
Sean,
Congrats and best of luck to you in your new endeavors. I hope we will
see you back around here in the future if things change again for you. I
appreciate all the work you did to stabilize and promote swig mapscript.
I hope we can find a new swig champion. I think it's great that
individuals are stepping up for the individual languages but Sean did a
great job insuring that all languages under swig were implemented in a
consistent way.
Thanks again Sean and I hope the new gig is a lot of fun.
-Steve W
On 5/26/06, Sean Gillies <sgillies at frii.com> wrote:
> Hey all,
> I've got a brand new gig starting in June that, while geospatial in
> nature, won't be making much direct use of MapServer, and won't allow
> me much time to respond to mapscript bugs. My time as owner of the
> SWIG mapscript Bugzilla component is done. Maybe you'll want to
> reassign to one person, or split it up by language, that's up to you.
> And since I don't foresee making many more big contributions to
> MapServer, I will resign my seat on the TSC as well, effective June
> 12. I'd like to retain commit privilege in order to make the odd bug
> fix here and there, but that's about the extent of my future
> involvement. I won't be supporting the Python test framework, or the
> mapscript.txt doc. To me, these are failed efforts, and the search
> should begin for something better.
> I'll stick around for Bugzilla through the end of June, so that a new
> component owner can be found, and I will of course be happy to assist
> that person or persons in taking over.
> cheers,
> Sean
> Sean Gillies
> http://zcologia.com
