server-side SLD support
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Wed Nov 1 11:03:49 EST 2006
Good questions Daniel. Let me try and answer them. I am sure Assefa will
correct me if necessary :-)
1) I have no problem with a shorter keyword like SLD
2) saving a MAP file will probably just save all the generated classes. I
don't see a problem with this approach.
3) I don't think get/set functions for Mapscript are necessary since there
is already a Mapscript function to generate them (applySLDURL on the
MapObj).
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Daniel Morissette <dmorissette at MAPGEARS.COM>
Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
Datum: 01/11/06 13:49
> Bart van den Eijnden (OSGIS) wrote:
> > Our plan is to add server-side SLD support to Mapserver WMS. This
would
> > involve adding a new keyword, for instance STYLEDLAYERDESCRIPTOR. It
will
> > add classes from the SLD document (matching the layer's name) to the
LAYER.
> I like the idea in general.
> A few questions/comments:
> - How'bout a shorter keyword such as SLD instead of STYLEDLAYERDESCRIPTOR?
> - What happens if you save a mapfile ($map->save()) that contains SLD
> definitions like this? Are they maintained in the saved mapfile or lost?
> - Are there ways to get and set SLD's via MapScript and if yes how does
> that work? i.e. does MapScript turn the SLD into a set of classes right
> away, or is the SLD just a string member of layerObj... actually an
> array of strings... or sldObj's? um... fun questions to answer...
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
