server-side SLD support
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Nov 1 11:07:13 EST 2006
> Hi list,
> I am talking to Assefa about getting Mapserver to support SLD
> documents server-side, and he said it might be good to start
> some discussion on the dev list. Quite some Web Map Services
> have this capability (Geoserver, Ionic), and it will make
> exchanging configuration between those environments and
> Mapserver easier.
This is great news. I believe the CubeWerx software would also benefit
from this.
> Note:
> * most the code is already in place
> * Mapserver does support SLD in its WMS client
> Our plan is to add server-side SLD support to Mapserver WMS.
> This would involve adding a new keyword, for instance
> STYLEDLAYERDESCRIPTOR. It will add classes from the SLD
> document (matching the layer's name) to the LAYER.
> Example:
> LAYER
> NAME "test"
> CLASS
> NAME "myfirstclass"
> END
> STYLEDLAYERDESCRIPTOR "/data/geoservices/nis/sld/nis/nis.sld"
Can this be a URL as well as a filepath?
> CLASS
> NAME "mylastclass"
> END
> END
> If the LAYER already has classes, the classes will be
> inserted/added depending on the sequence of the keywords. So
> in the above example the classes generated from the SLD will
> be appended after "myfirstclass" but inserted before "mylastclass".
> Are there any objections against this? Or thoughts/concerns?
> Thanks in advance.
> Best regards,
> Bart
> Bart van den Eijnden
> OSGIS, Open Source GIS
> http://www.osgis.nl
