server-side SLD support
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Wed Nov 1 13:11:15 EST 2006
Tom, yes both an URL and a filepath would be possibilities.
Best regards,
Bart
Kralidis,Tom [Burlington] schreef:
>> Hi list,
>> I am talking to Assefa about getting Mapserver to support SLD
>> documents server-side, and he said it might be good to start
>> some discussion on the dev list. Quite some Web Map Services
>> have this capability (Geoserver, Ionic), and it will make
>> exchanging configuration between those environments and
>> Mapserver easier.
> This is great news. I believe the CubeWerx software would also benefit
> from this.
>> Note:
>> * most the code is already in place
>> * Mapserver does support SLD in its WMS client
>> Our plan is to add server-side SLD support to Mapserver WMS.
>> This would involve adding a new keyword, for instance
>> STYLEDLAYERDESCRIPTOR. It will add classes from the SLD
>> document (matching the layer's name) to the LAYER.
>> Example:
>> LAYER
>> NAME "test"
>> CLASS
>> NAME "myfirstclass"
>> END
>> STYLEDLAYERDESCRIPTOR "/data/geoservices/nis/sld/nis/nis.sld"
> Can this be a URL as well as a filepath?
>> CLASS
>> NAME "mylastclass"
>> END
>> END
>> If the LAYER already has classes, the classes will be
>> inserted/added depending on the sequence of the keywords. So
>> in the above example the classes generated from the SLD will
>> be appended after "myfirstclass" but inserted before "mylastclass".
>> Are there any objections against this? Or thoughts/concerns?
>> Thanks in advance.
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
bartvde at osgis.nl
http://www.osgis.nl
