server-side SLD support
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Nov 1 16:30:32 EST 2006
Yewondwossen Assefa wrote:
> I am more leaning to say that we should not save the classes generated,
> but only the SLD (marking the classes as temporary as you suggested).
> But when we talk about save, it is done through mapscript, so the users
> will have the ability to manipulate the classes before saving the map
> and next reload of the map will givent diffrent result.
> If it is a documented and acceptable limitation, I do not see any
> problem discarding the new classes created.
This kind of inconsistent behavior makes me nervous. What you propose
reopens the questions that I sent earlier this morning.
I mean someone could load a mapfile with MapScript, not knowing that it
contained a SLD ref. Then modify a few classes (including some coming
from a SLD) or insert new classes and save the map, expecting the
changes to be saved, but then because the MapScript code was not
SLD-aware the changes would actually be lost and odd side-effects might
happen next time the saved map is loaded.
I'm also not clear on whether the current ApplySLD() method is
sufficient for MapScript apps to interact with this feature if you plan
to maintain both the SLD ref and a set of temporary classes in memory.
>> Maybe if we don't allow people to mix SLD and CLASSes, it would make
>> life easier? But still the generated classes would need to be removed
>> and the SLD keyword written upon saving.
> I still think we should allow the mixing of SLD and CLASS elements and
> mark SLD generated classes as "non savable"
Mixing SLD and CLASS elements would be nice, but if that becomes the
source of odd side-effects for apps that are not SLD-aware then that's
not good.
Daniel
Daniel Morissette
http://www.mapgears.com/
