server-side SLD support
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Mon Nov 6 09:24:47 EST 2006
Bart van den Eijnden (OSGIS) wrote:
> True.
> So in order to do this safely, we would need to have the concept of
> immutable classes in Mapserver, or not? I.e. classes the user cannot change.
> Or are there other solutions?
  Maybe another thing that comes into mind is the ability to have the
sld loaded per layer (or even at the map level) and then have sldclass
tags that can use a name to refer to a class name in the sld.  There is
definitely more work attached to it but It might be something to explore.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Daniel Morissette <dmorissette at MAPGEARS.COM>
> Naar: MAPSERVER-DEV at LISTS.UMN.EDU <MAPSERVER-DEV at LISTS.UMN.EDU>
> Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
> Datum: 02/11/06 10:40
>>&gt; Paul,
>>&gt;
>>&gt; the intention of the SLD keyword would be to be used in server-side
> WMS
>>&gt; implementations, to be used as the default style.
>>&gt;
>>&gt; So I would not recommend using it in Chameleon client MAP files.
>>&gt;
>>&gt; Maybe we are putting the scope of this too wide ..... ?
>>&gt;
>>Once a feature is out in the wild then users will start using it for all
>>sorts of things that you never expected, and what you recommend them to
>>do or not do won't matter... i.e. even if you recommend to Chameleon
>>users to not use mapfiles that contain SLD refs, some of them will do it
>>either intentionally or by accident... that's why we need to address all
>>those questions now, to avoid making a half-baked feature available that
>>will cause odd side-effects to previously working applications.
>>Daniel
>>Daniel Morissette
>>http://www.mapgears.com/
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
