server-side SLD support
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Mon Nov 6 09:31:18 EST 2006
Hi Assefa,
from a user point of view, this does not have my preference.
Still I would need to code a lot of (SLD)CLASSes into the Mapserver MAP file
(although they only need to have a NAME but still) in order to use an SLD
for the styling.
I would want to have the ability to use an SLD out of the box, by just
referencing the SLD file.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: yassefa at dmsolutions.ca
Naar: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>
Cc: MAPSERVER-DEV at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
Datum: 06/11/06 12:25
> Bart van den Eijnden (OSGIS) wrote:
> &gt; True.
> &gt;
> &gt; So in order to do this safely, we would need to have the concept of
> &gt; immutable classes in Mapserver, or not? I.e. classes the user cannot
change.
> &gt;
> &gt; Or are there other solutions?
> &gt;
>   Maybe another thing that comes into mind is the ability to have the
> sld loaded per layer (or even at the map level) and then have sldclass
> tags that can use a name to refer to a class name in the sld.  There is
> definitely more work attached to it but It might be something to explore.
> &gt; Best regards,
> &gt; Bart
> &gt;
> &gt; --
> &gt; Bart van den Eijnden
> &gt; OSGIS, Open Source GIS
> &gt; http://www.osgis.nl
> &gt;
> &gt;
> &gt; --------- Oorspronkelijk bericht --------
> &gt; Van: Daniel Morissette &lt;dmorissette at MAPGEARS.COM&gt;
> &gt; Naar: MAPSERVER-DEV at LISTS.UMN.EDU &lt;MAPSERVER-DEV at LISTS.UMN.EDU&gt;
> &gt; Onderwerp: Re: [UMN_MAPSERVER-DEV] server-side SLD support
> &gt; Datum: 02/11/06 10:40
> &gt;
> &gt;
> &gt;&gt;Bart van den Eijnden (OSGIS) wrote:
> &gt;&gt;&amp;gt; Paul,
> &gt;&gt;&amp;gt;
> &gt;&gt;&amp;gt; the intention of the SLD keyword would be to be used in
server-side
> &gt;
> &gt; WMS
> &gt;
> &gt;&gt;&amp;gt; implementations, to be used as the default style.
> &gt;&gt;&amp;gt;
> &gt;&gt;&amp;gt; So I would not recommend using it in Chameleon client MAP
files.
> &gt;&gt;&amp;gt;
> &gt;&gt;&amp;gt; Maybe we are putting the scope of this too wide ..... ?
> &gt;&gt;&amp;gt;
> &gt;&gt;
> &gt;&gt;Once a feature is out in the wild then users will start using it
for all
> &gt;&gt;sorts of things that you never expected, and what you recommend
them to
> &gt;&gt;do or not do won't matter... i.e. even if you recommend to
Chameleon
> &gt;&gt;users to not use mapfiles that contain SLD refs, some of them will
do it
> &gt;&gt;either intentionally or by accident... that's why we need to
address all
> &gt;&gt;those questions now, to avoid making a half-baked feature
available that
> &gt;&gt;will cause odd side-effects to previously working applications.
> &gt;&gt;
> &gt;&gt;Daniel
> &gt;&gt;--
> &gt;&gt;Daniel Morissette
> &gt;&gt;http://www.mapgears.com/
> &gt;&gt;
> &gt;&gt;
> &gt;
> &gt;
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
