Problems running version 4.10.0 rc1
José Vicente Higon
higon_jos at GVA.ES
Fri Oct 6 04:21:52 EDT 2006
Frank Warmerdam escribió:
> José Vicente Higon wrote:
>> Hello,
>> I've compiled mapserver 4.10.0 rc1 with gdal 1.3.2 on linux and I've
>> realized two problems:
>> 1. If compile with geos I get an error like this:
>> mapgeos.c:34:20: geos_c.h: File not found
> José,
> Can you provide details on what version of GEOS you were using, and
> what the compile line for mapgeos.c looked like? MapServer now requires
> a relatively recent GEOS (2.2.3?) but I suspect the problem you are
> running
> into is some sort of include path issue.
Ok, you're right, using the 2.2.3 It compiles. Thanks.
>> 2. I can't get get an image with output format trought GDAL like
>> "tiff 32 bit float". Mapserver returns a 500 html code (mapserver
>> crashes).
>> The outputformat definition is like this :
>> OUTPUTFORMAT
>> NAME GTiffFloat
>> DRIVER "GDAL/GTiff"
>> MIMETYPE "image/tiff; mode=float32"
>> IMAGEMODE FLOAT32
>> EXTENSION "tif"
>> END
> The automated tests include some options somewhat like this, so I *think*
> this is usually working. I'm not sure how to start isolating why it
> doesn't work for you. I would suggest trying map with shp2img, and see
> if you can reproduce the problem there. If so, then perhaps you could
> try running it in the debugger to get a traceback for the problem.
It's quite extrange !! If I define a legend object mapserver crashes.
But If I don't do it mapserver runs perfectly.
> You might also try a different format to see if it is only with TIFF.
> For instance, change DRIVER "GDAL/GTiff" to DRIVER "GDAL/HFA" which also
> supports FLOAT32 data. If HFA works, and GTiff does not we can presume
> some sort of libtiff specific issue. If neither works, then we likely
> need to get to the point where I can reproduce the problem at my end.
> If you can provide me temporary ssh access to your system I could help
> debug the problem.
It's imposible, but I can give you the mapfile and the datasource.
> Best regards,
Thank you very much.
José Vicente Higón
Grupo de desarrollo de gvSIG
Conselleria de Infraestructuras y Transporte
Generalitat Valenciana
Valencia - Spain
http://www.gvsig.gva.es
