mapserver WMS time and postgis.
Denis Nadeau
denis.nadeau at GMAIL.COM
Tue Oct 10 11:06:56 EDT 2006
Right now, I need to do some testing on the SQL commands, to be sure that
all possibilities are coded. I'll keep you in the loop.
Denis
2006/10/6, Steve Lime <Steve.Lime at dnr.state.mn.us>:
> We need to get WCS time support and WMS time support in sync. Please
> include me on the bug...
> Steve
> >>> Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> 10/04/06 2:54 PM >>>
> Denis,
> Sorry for the delay.
> Please enter a bug (WMS Server module) and code contribution and I
> will integrate it in mapserver.
> Thanks.
> Denis Nadeau wrote:
> > Hi,
> > I would like to change some of the code in mappostgis.c to reflect C
> > 5.2 Nearest Value instructions found in WMS 1.1.1 specifications for
> > "TIME" parameter.
> http://portal.opengeospatial.org/files/?artifact_id=1081&version=1&format=pdf
> > Here what it says in the WMS 1.1.1 doc.
> > "If a request does includes an imprecise dimensional value, and
> nearest
> > value behavior has been declared, then the server shall compute and
> send
> > the nearest available value. The value shall be rounded, not merely
> > truncated."
> > Right now, mapserver is using date_trunc function to allow the user to
> > specify months, days, hours or minutes. I think this could be
> enhanced
> > to get the nearest time value in Postgres. For example, NASA GES has
> 3
> > hourly data. If the user specify 2006-09-28T02:00 a blank image is
> > return, the user needs to be exact 2006-09-28T03:00. Same thing with
> > 10-day data, 2006-09-03 will return a blank image. User have to
> hit
> > the right date 2006-08-10, 2006-08-20, 2006-08-31, 2006-09-10,....
> > Example
> > Tropical Rain data 3B42_V6_10_DAY:
> http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20
> > blank image
> http://g0hep12u.ecs.nasa.gov/mapserv-bin/wms_ogc?SERVICE=WMS&VERSION=1.1.1&REQUEST=Getmap&layers=bluemarble,TRMM_3B42_V6_10_DAY&BBOX=-180,-50,180,50&TIME=2005-08-20T04:00
> > Let me know if this make sense to you. I would be happy to contribute
> > some coding for this.
> > Denis
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20061010/af673bc5/attachment.html
