Revised RFC 1 - Need Comments
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Oct 11 13:48:07 EDT 2006
1. I'm all in favor of transparency, in what responsibilities are and
who is making
decisions. Trouble is coming up with the laundry list of proposed areas
the PSC
has authority. Perhaps that's a good point of discussion.
2. I was thinking sub-committees when I altered that portion of the
document.
3. RFC numbering? I asked about that way back when I started to edit
this.
There were some comments about this RFC replacing number 1 as opposed
to
sitting alongside it. The 1a designation was simply a quick choice on
my part.
I'd be perfectly happy calling this RFC 20 since I think the original
RFC 1 needs
to be available long term as originally written.
One thing I'm uncomfortable with is the TSC annointing itself as the
PSC. But then
again I don't know how that should happen. Perhaps the TSC as it sits
with 2 or 4
open memberships (with a community-based nomination, or even voting
process)
is a good compromise.
Steve
>>> Daniel Morissette <dmorissette at MAPGEARS.COM> 10/11/2006 11:26:27 AM
Steve Lime wrote:
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-1a
> Feel free to edit, pass along comments, concerns or whatever...
A few comments:
1- Area of authority/responsibilities:
I think the area of responsibilities of the PSC should be defined. All
that I find in the current document is "... makes decisions on
project issues - both technical and non-technical." I guess this
implies
that the PSC mandate is to make decisions on any question that relates
to MapServer, but that's only implied and not made explicitly clear. If
we want the PSC to be the ultimate decision making authority for
anything that relates to MapServer then should we not state that
clearly
in this document? I'm just trying to avoid repeating what happened
during the "should MapServer join OSGeo?" discussions when we realized
that there was nobody with clear authority to make that decision.
OTOH, if someone thinks that the PSC should not be the ultimate
authority with respect to MapServer then we should define what the
limits of its authority are and who else is responsible for questions
outside of those limits.
2- Subcommittees or parallel committees?
RFC-1a says: "It is anticipated that seperate "committees" will exist
to
manage conferences, documentation and web sites. That said, it is
expected that the PSC will be the entity largely responsible for
creating any such committees."
Would conference, docs, website and other committees be sub-committees
or parallel committees? My first idea is to think that they should be
sub-committees who report to the PSC, a bit like OSGeo committees
report
to the OSGeo board via their chairs. However if others think
differently
I'm open to discussion, but either way I think the relationship needs
to
be made clear here.
3- RFC numbering:
I find that reusing RFC numbers for revised documents can lead to
confusion. I think RFCs should be set in stone after they have been
adopted. In this case calling the revised version RFC-1a isn't that
bad,
but would it not be more clear if this new doc was called RFC-20 with a
note in RFC-1 that it is obsolete and superceeded by RFC-20 (and a note
in RFC-20 that it is obsoletes RFC-1)?
This way RFC-1 remains available for reference by people reading old
mail archives or reading old documents that were built against RFC-1,
and RFC-20 becomes the new reference for new discussions.
I guess calling this revised doc RFC-1a makes some sense since it is
the
root of the committee and we want that to be RFC-1-something, but for
any other RFCs I think using new numbers and obsoleting old RFCs would
make more sense. Using new RFC numbers would also allow for a single
RFC
to obsolete several old RFCs at once, which would be impossible if our
approach is to call revised docs RFC-11a, RFC-11b, etc.
My 0.02$... I'd like to hear what others think on those topics.
Daniel
Daniel Morissette
http://www.mapgears.com/
