mapowscommon first pass attempt
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Thu Oct 19 23:26:29 EDT 2006
All,
I've completed a standalone first pass at implementing OWS Common 1.0.0
support (http://www.opengeospatial.org/standards/common), via
mapowscommon.c and mapowscommon.h.
Assefa and Dan have provided an initial code review (thanks guys).
The code initially implements clauses/subclauses 7.4.3, 7.4.4, 8, 10.2.1
and 10.2.2.
The code uses libxml2 to do the XML marshalling.
Using mapogcsos.c as an example (since the SOS code actually uses OWS
Common, I think this is the best place to get started), the way I
envision this code being used is:
- mapogcsos.c sets up libxml2 objects
- mapogcsos.c calls mapowscommon.c functions as appropriate
- mapowscommon.c returns libxml2 objects (XML chunks) to mapogcsos.c
The last bullet of RFC 7 states:
"If new files or library dependencies are added, then the configure.in,
Makefile.in, Makefile.vc and related documentations should be kept up to
date."
Is there a any step-by-step process on how one integrates new code (as
far as integrating into the files above, etc.)?  I guess I'm looking for
some integration help for a first timer here :)
Thanks
..Tom
