Filter in Mapserver 4.10.0
Steve Lime Steve.Lime at DNR.STATE.MN.US
Tue Oct 24 01:01:31 EDT 2006
Ok, found and fixed the problem. It wasn't an issue with the lexer changes Paul refers to
rather an issue with some cleanup done in loadExpressionString in mapfile.c. I made a
mistake and let the lexer check for simple expression strings when in reality that's should
be the default case if an expression is not a regex, logical or case insensitive.
I have fixed in both 4.10 and 5.0 if anyone would care to confirm...
Steve
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 10/23/06 12:33 PM >>>
Will look into it...
Steve
>>> Paul Ramsey <pramsey at REFRACTIONS.NET> 10/19/2006 2:59:10 PM >>>
I assume this traces back to this commit:
revision 1.101
date: 2006/08/15 06:18:49;  author: sdlime;  state: Exp;  lines: +5 -34
Simplified quoted string rules in maplexer.l, just or'd together the
single and
double qoute regular expressions. Updated include detection to
support single
quotes as well.
On 19-Oct-06, at 12:21 PM, Andreas Albarello wrote:
> Sture Dingsøyr wrote:
>> The code below fails:
>> $poLayer = $mapObject->getLayerByName($layerId[$i]);
>> $poLayer->set("status", 1);
>> $poLayer->setFilter("navn = 'Fjaler'");
>> I get this error message:
>> DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection
>> (force_2d(the_geom)),'NDR'),gid::text from (SELECT * FROM
>> n2000ko_f) AS n2000ko_f WHERE (navn = ) and (the_geom && setSRID
>> ( 'BOX3D(-647132 6410334.17468806,1689132
>> 7988665.82531194)'::BOX3D,32633) )
> Sture,
> I've experienced exactly the same problem with Mapserver 4.10.0.
> Don't know if this should be considered a bug, but it is a
> backwards compatibility issue with existing mapscript applications
> at least. I believe this behavior has been caused by some recent
> changes to the mapfile lexer.
> There's however a workaround for this. The following should do the
> trick:
> $poLayer->setFilter("\"navn = 'Fjaler'\"");
> Best regards,
> Andreas Albarello
> Analysis & SW Development
> Territorium Online srl/GmbH
> Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
> email: andreas.albarello at territoriumonline.com
> web:   www.territoriumonline.com
