MapServer 4.10-beta2 problems
Grefe, Jochen
jochen at INGENIEURTEAM2.COM
Mon Sep 4 07:42:39 EDT 2006
Hello,
I tried to send this to the users list but I can't subscribe to the list.
Nevertheless, I think experiences from the new version are interesting
enough to disturb you.
I compiled mapserver successfully with msvc 2005. And I get two errors
in our existing mapserver application.
The first is issued through "Bug 1536 Mapserver postgis driver does not
quote field names with special characters" because I use expressions on
the select query. Uncommenting the two "strcat(columns_wanted, "\"");" lines
solved this.
The second has the error message :
msOGRFileNextShape(): OGR error. SetAttributeFilter () not supported on
ExecuteSQL() results
This happens on a virtual point layer working on a ODBC connection.
Due to the better error reporting integrated in version 1.96:
* Revision 1.96 2006/04/08 03:36:48 frank
* Ensure that an error in GetNextFeature() will be properly translated
* into a MapServer error in GetNextShape().
it raised an error from the underlying driver. Uncommenting the error
handling and returning MS_DONE let everything work again.
This happened with a new compiled (MSVC8) gdal 1.3.2 and also with the
Revision 1.4 of ogrodbcselectlayer.cpp.
Hope this is interesting enough,
Best regards jochen
P.S.: Environment:
Windows Server 2003 Service Pack 1
SQL Server 2000 Service Pack 4
All updates applied.
This is all I build with MSVC8
curl-7.15.5
freetype-2.1.10
gd-2.0.33
gdal cvs 1.3.2
geos svn 2.2.3
gettext-0.14.6
jpeg-6b
libiconv-1.9.2
libpng-1.2.12
mapserver 4.1.10 beta 2
ming-0.2a
PDFlib-Lite-6.0.3
Pgsql cvs 8.1.4
proj-4.4.9
regex-0.12
swigwin-1.3.29
zlib-1.2.3
