OracleSpatial attribute queries
Hallgren Johan E
jhhal at WMDATA.COM
Thu Sep 14 04:30:02 EDT 2006
This is an old question but still the problem remains.
I use MapServer/MapScript/csharp.
I use the OracleSpatial built in support in MapServer.
I want to show a selected bunch of features on the map. The selection is
made only by an attribute query (postcode = 123).
By turning logging on I can se that even if I do an attribute query the
query sent to Oracle include both the envelope and the actual query.
I can catch that query and run it in SQLPlus and I will see it takes
looonnngg time to perform. If I remove the envelope it's much faster. I
have created index on both the geometry and the attribute column, but as
I can understand it's not possible to create index on shape and the
attribute column in combination.
So my question is: why must the geometry be part of the query when I
don't need it?
/Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060914/864aa1aa/attachment.html
