MapScript, C#, delete_classObj exception
Hallgren Johan E jhhal at WMDATA.COM
Thu Sep 14 04:30:00 EDT 2006
Hello
I use the 4.8.4 release of MapServer and I'm using csharp/Mapscript
option. The problem is that I could run a sequence of calls with no
problems and I can do it a number of times but suddenly I have problems.
The special things I do is that:
*         I use the same mapObj several times, in the same process, for
servral requests.
*         I create inline features dynamically.
*         I create layers for inline features dynamically.
*         I create classes for those dynamically.
After the image is created, I tries to clean up (restore) the stage to
how it was before the request. That where I have problems, in some
cases.
In my log file I can read:
2006-04-12 20:23:44 mapscript_csharp
Object reference not set to an instance of an object.
   at mapscriptPINVOKE.delete_classObj(HandleRef jarg1)
   at classObj.Dispose()
   at classObj.Finalize()
It's really all I can say for the moment. After restarting the process
it runs thru as it should, no problems with cleaning up.
Any clues?
/Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com
<BLOCKED::mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se
<BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060914/6af55d3e/attachment.html
