QA and Python mapscript unit tests
Normand Savard nsavard at MAPGEARS.COM
Wed Sep 13 11:15:23 EDT 2006
I run python mapscript unit tests on MapServer on Linux for a while on
various version of MapServer and I'm still having some errors and
failures that I cannot get rid of.  Actually I run the tests on
MapServer rel-4-10-0-beta3 version and I get three failures and 10
errors.  I compare my results with the ones found on
http://mapserver.builds.hobu.net.  I post this message here in case
someone knows why these errors and failures happens.
On http://mapserver.builds.hobu.net the following tests passed:
OWSRequestTestCase.testGetParameter
OWSRequestTestCase.testGetParameterByName
OWSRequestTestCase.testInit
OWSRequestTestCase.testLoadWMSRequest
OWSRequestTestCase.testResetParam
But when I run these tests I get this error:
request = mapscript.OWSRequest()
AttributeError: 'module' object has no attribute 'OWSRequest'
I have all OWS configuration switches enabled when I build MapServer.
See my configuration command line:
configured by ./configure, generated by GNU Autoconf 2.59,
  with options \"'--prefix=/home/testsuite/fgs-ms410/built/mapserver'
'--with-gdal=/home/testsuite/fgs-ms410/built/gdal/bin/gdal-config'
'--with-ogr=/home/testsuite/fgs-ms410/built/gdal/bin/gdal-config'
'--with-gd=/home/testsuite/fgs-ms410/built/gd/'
'--with-libiconv=/home/testsuite/fgs-ms410/built/libiconv/'
'--with-png=/home/testsuite/fgs-ms410/built/libpng'
'--with-proj=/home/testsuite/fgs-ms410/built/proj'
'--with-curl-config=/home/testsuite/fgs-ms410/built/curl/bin/curl-config'
'--with-wmsclient' '--with-wfs' '--with-wfsclient' '--with-wcs'
'--with-postgis=/home/testsuite/fgs-ms410/built/postgresql/bin/pg_config'
'--with-php=/home/testsuite/fgs-ms410/built/php'
'--with-httpd=/home/testsuite/fgs-ms410/built/apache/bin/httpd'
'--without-pdf' '--without-xpm' '--without-tiff'\"
Beside that I get four errors with PostGreSQL which is normal since I
have no PostGreSQL database.  I have also the following error with
testSetValue test.  This error is also found on
http://mapserver.builds.hobu.net:
MapServerError: setValue(): Shapefile error. Can't set value
Finally I get three failures:  testClearExpression, testAlterNumPoints
and testNullValue.  These failures appear on
http://mapserver.builds.hobu.net as well.  On
http://mapserver.builds.hobu.net there is one additional failure:
testGetPointWKT.
Thanks for any hints.
Norm
