mapserver fastcgi memory leak
Ehud Shabtai
eshabtai at GMAIL.COM
Wed Sep 13 11:08:14 EDT 2006
On 9/13/06, Ehud Shabtai <eshabtai at gmail.com> wrote:
> On 9/12/06, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> > Ehud: Have you tried another version of Freetype or are you using the
> > latest/greatest?
> I'm using freetype-2.1.10.
> The latest is 2.2.1. It seems that my system is not yet ready for an
> upgrade to 2.2.x (2.2.x hides some undocumented interfaces and some of
> my packages are not compatible with it).
> The fact that the leak comes from freetype doesn't necessarily point
> to a problem in freetype, it might be a problem in GD, or Mapserver.
Well, it is a freetype leak, at least most of it.
I've been using the arialbd.ttf font and that seems to be the cause.
Using a pfa font instead of the ttf font does not cause any leaks!
As I'm using an old freetype version, I can't verify if the leak
exists in the latest version. Can anyone else verify this?
I did find two small leaks in mapserver. The attached patch fixes them.
Thanks,
Ehud Shabtai
http://www.freemap.co.il/map/
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20060913/52c16b2e/ms_leak_fix.bin
