RFC-24 Mapscript memory management: call for votes
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Apr 2 11:07:43 EDT 2007
I'm getting to ready to go then...
Thanks to all,
Umberto
On 4/2/07, Tamas Szekeres <szekerest at gmail.com> wrote:
> Steve,
> I have no doubt that you are a TSC member. The only confusion I have
> is that how many TSC member vote is required to pass the proposal
> whether the proposer is a TSC member or not.
> Nevertheless, having another +1 from Howard the current state of this
> voting has become obvious.
> Best regards,
> Tamas
> 2007/4/2, Stephen Woodbridge <woodbri at swoodbridge.com>:
> > Tamas,
> > I am on the TSC. RFC1 only reflects the founding members I was added
> > later. You will see me listed in RFC23. It is not easy to find a current
> > list of TSC members, we should probably fix that.
> > -Steve W.
> > Tamas Szekeres wrote:
> > > Umberto,
> > > According to #6 only members of the Technical Steering Committee's
> > > votes will be counted so you should wait for another +1 from a TSC
> > > member before announcing the results and committing the changes,
> > > Best regards,
> > > Tamas
> > > 2007/4/2, Umberto Nicoletti <umberto.nicoletti at gmail.com>:
> > >> Currently the voting request has been on line for over a week and it
> > >> is going as follows:
> > >> +2 (me, Stephen Woodbridge)
> > >> +0 Frank Warmerdam
> > >> I have reread RFC1, and according to item 7 I can consider it approved
> > >> even though I'd hoped to see some more votes.
> > >> Anyway, I'll update the rfc with a compatibility section to comply
> > >> with Stephen's requirements and then I'll start committing changes. I
> > >> should be done by next week (sunday 14) because of Easter and some
> > >> other projects' deadlines in this week.
> > >> Thanks to all,
> > >> Umberto
> > >> On 3/24/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > >> > I took some time to update the RFC text at:
> > >> > http://mapserver.gis.umn.edu/development/rfc/ms-rfc-24
