SLD and WFS: filters
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Wed Apr 4 04:50:24 EDT 2007
Hi list,
does the Mapserver SLD code handle filters differently than the WFS code?
We've run into the following problem that suggests the above. I suspect
that, for SLD, Mapserver internally will do the query and for WFS Mapserver
will let OGR do it.
Our SLD works fine, but if we use the same ogc:Filter in WFS it fails with:
msOGRFileWhichShapes(): OGR error. SetAttributeFilter( (KW_KWALITE> 3) )
failed on layer kw20070131.
Attempt to use STRING field `KW_KWALITE' with numeric comparison `>'.
So apparently OGR cannot handle the > operator on a string field, but
Mapserver can?
Shouldn't the two interfaces (SLD WMS and WFS) use the same approach
otherwise this can lead to inconsistent results?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
