build error
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue Apr 17 10:38:56 EDT 2007
on FC6, using latest CVS, using:
$ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
/gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
--with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
/usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
src/agg/agg-2.5/
mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
mapswf.c:1326: error: expected â)â before â;â token
mapswf.c:1539: warning: assignment from incompatible pointer type
mapswf.c:1539: error: expected â;â before â}â token
mapswf.c:1266: warning: unused variable âfcâ
I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c. Checking HEAD shows numerous updates related to RFC 24. As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
..Tom
