build error
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Apr 18 11:16:32 EDT 2007
I was able to build php mapscript with the changes I have sent you. If
I try to load php_mapscript I get this error:
--------------/BEGIN
<HTML>
<BODY>
Warning: dl(): Unable to load dynamic library
'/usr/lib/php5/20060613+lfs/php_mapscript.so' -
/usr/lib/php5/20060613+lfs/php_mapscript.so: cannot open shared
object file: Too many levels of symbolic links in
/home/unicoletti/Workspace/scratch/mapserver/mapscript/php3/test.php
on line 11
phpinfo()
PHP Version => 5.2.1
System => Linux ziggy 2.6.20-14-generic #2 SMP Mon Apr 2 20:37:49 UTC 2007 i686
Build Date => Feb 20 2007 19:08:11
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc/php5/cli/php.ini
Scan this dir for additional .ini files => /etc/php5/cli/conf.d
additional .ini files parsed => /etc/php5/cli/conf.d/ldap.ini,
/etc/php5/cli/conf.d/mysql.ini,
/etc/php5/cli/conf.d/mysqli.ini,
/etc/php5/cli/conf.d/pdo.ini,
/etc/php5/cli/conf.d/pdo_mysql.ini,
/etc/php5/cli/conf.d/pdo_pgsql.ini,
/etc/php5/cli/conf.d/pgsql.ini
PHP API => 20041225
PHP Extension => 20060613
Zend Extension => 220060519
Debug Build => no
Thread Safety => disabled
Zend Memory Manager => enabled
IPv6 Support => enabled
Registered PHP Streams => zip, php, file, data, http, ftp,
compress.bzip2, compress.zlib, https, ftps
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl,
sslv3, sslv2, tls
Registered Stream Filters => string.rot13, string.toupper,
string.tolower, string.strip_tags, convert.*, consumed,
convert.iconv.*, bzip2.*, zlib.*
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.2.0, Copyright (c) 1998-2007 Zend Technologies
--------------/END
Maybe because php5 is not supported?
Umberto
On 4/18/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> I hope that's the last error!
> Change the line to read as:
> map->layers[map->numlayers]->index = map->numlayers;
> that is: change the dot before index to an arrow.
> Umberto
> On 4/18/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > Thx. Here's what I get after applying the patches to mapscript_i.c and php_mapscript.c:
> > $ make
> > mapscript_i.c: In function "layerObj_new":
> > mapscript_i.c:462: error: request for member "index" in something not a structure or union
> > make[1]: *** [mapscript_i.o] Error 1
> > make[1]: Leaving directory `/usr/local/src/mapserver/cvs/mapserver/mapscript/php3'
> > -----Original Message-----
> > From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> > Sent: Wed 18-Apr-07 10:54
> > To: Kralidis,Tom [Burlington]
> > Cc: MAPSERVER-DEV at lists.umn.edu
> > Subject: Re: [UMN_MAPSERVER-DEV] build error
> > I don't have an environment to build php yet, so I din't test them but
> > the following two patches should fix your build.
> > Please note that they don't add reference counting to php mapscript,
> > they simply allow php mapscript to build on latest cvs.
> > Let me know how it goes.
> > Umberto
> > > Thx. The patches seemed to work, but now
> > > $ patch -p0 < rfc24-pathKralidis-mapogcsld.patch
> > > patching file mapogcsld.c
> > > $ patch -p0 < rfc24-pathKralidis-mapswf.patch
> > > patching file mapswf.c
> > > $ make
> > > mapogcfilter.o
> > > mapogcfilter.c: In function âFLTGetQueryResultsForNodeâ:
> > > mapogcfilter.c:375: warning: assignment from incompatible pointer type
> > > mapogcfilter.c:381: error: expected identifier before â)â token
> > > mapogcfilter.c:559: error: expected â;â before â}â token
> > > mapogcfilter.c:610: error: invalid storage class for function âaddResultâ
> > > mapogcfilter.c: In function âFLTAddToLayerResultCacheâ:
> > > mapogcfilter.c:659: warning: assignment from incompatible pointer type
> > > mapogcfilter.c: In function âFLTArraysNotâ:
> > > mapogcfilter.c:761: warning: assignment from incompatible pointer type
> > > mapogcfilter.c: In function âFLTApplySimpleSQLFilterâ:
> > > mapogcfilter.c:998: warning: assignment from incompatible pointer type
> > > mapogcfilter.c:1047: error: expected identifier before â)â token
> > > mapogcfilter.c:1070: error: expected â;â before â}â token
> > > mapogcfilter.c:996: warning: unused variable âpszBufferâ
> > > mapogcfilter.c:994: warning: unused variable âmsErrâ
> > > mapogcfilter.c:988: warning: unused variable âszExpressionâ
> > > mapogcfilter.c: In function âFLTApplyFilterToLayerâ:
> > > mapogcfilter.c:1151: warning: initialization from incompatible pointer type
> > > mapogcfilter.c: In function âFLTLayerApplyPlainFilterToLayerâ:
> > > mapogcfilter.c:1196: warning: assignment from incompatible pointer type
> > > mapogcfilter.c:3624: error: expected declaration or statement at end of input
> > > mapogcfilter.c:348: warning: unused variable âdfCurrentToleranceâ
> > > mapogcfilter.c:344: warning: unused variable âpanResultsâ
> > > mapogcfilter.c:343: warning: unused variable âsProjTmpâ
> > > mapogcfilter.c:342: warning: unused variable ânTokensâ
> > > mapogcfilter.c:341: warning: unused variable âtokensâ
> > > mapogcfilter.c:336: warning: unused variable âiâ
> > > mapogcfilter.c:336: warning: unused variable ânEpsgTmpâ
> > > make: *** [mapogcfilter.o] Error 1
> > > ..so then I made changes to mapogcfilter.c:
> > > $ cvs diff mapogcfilter.c
> > > Index: mapogcfilter.c
> > > RCS file: /data2/cvsroot/mapserver/mapogcfilter.c,v
> > > retrieving revision 1.71
> > > diff -r1.71 mapogcfilter.c
> > > 381c381
> > > < initClass(&(lp->class[0]->);
> > > > initClass(&(lp->class[0]));
> > > 408c408
> > > < initClass(&(lp->class[1]->);
> > > > initClass(&(lp->class[1]));
> > > 1047c1047
> > > ...and then receive the following error:
> > > php_mapscript.c: In function âphp3_ms_map_getAllLayerNamesâ:
> > > php_mapscript.c:3903: error: request for member ânameâ in something not a structure or union
> > > make[1]: *** [php_mapscript.o] Error 1
> > > $ make
> > > php_mapscript.c: In function "php3_ms_map_getAllLayerNames":
> > > Again, I have not committed anything as this looks like a bunch of wholesale changes.
> > > ..Tom
> > > From: UMN MapServer Developers List on behalf of Umberto Nicoletti
> > > Sent: Wed 18-Apr-07 05:24
> > > To: MAPSERVER-DEV at LISTS.UMN.EDU
> > > Cc:
> > > After applying the following two patches mapserver *compiles* in this
> > > configuration.
> > > ./configure --with-threads --without-pdf --without-tiff --with-gdal
> > > --with-proj --with-geos --with-ming --with-ogr --with-wms --with-wcs
> > > --with-sos -with-agg --with-wmsclient --with-wfsclient --with-eppl
> > > I am on Ubuntu Feisty.
> > > I cannot apply the patches today, since I am at a customer site
> > > without cvs access.
> > > Please report status so I can commit the changes asap.
> > > Umberto
> > > > I'm working on fixing it...
> > > > I'll make a patch available later today.
> > > > Umberto
> > > > On 4/17/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > > > > on FC6, using latest CVS, using:
> > > > > $ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
> > > > > ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
> > > > > /gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
> > > > > --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
> > > > > /usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
> > > > > src/agg/agg-2.5/
> > > > > mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
> > > > > mapswf.c:1326: error: expected â)â before â;â token
> > > > > mapswf.c:1539: warning: assignment from incompatible pointer type
> > > > > mapswf.c:1539: error: expected â;â before â}â token
> > > > > mapswf.c:1266: warning: unused variable âfcâ
> > > > > I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c. Checking HEAD shows numerous updates related to RFC 24. As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
> > > > > ..Tom
