build error
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Apr 18 11:37:40 EDT 2007
With this change, the code builds.
Umberto: if you want me to commit your patches, let me know and I will do so.
-----Original Message-----
From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
Sent: Wed 18-Apr-07 11:04
To: Kralidis,Tom [Burlington]
Cc: MAPSERVER-DEV at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-DEV] build error
I hope that's the last error!
Change the line to read as:
map->layers[map->numlayers]->index = map->numlayers;
that is: change the dot before index to an arrow.
Umberto
On 4/18/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> Thx. Here's what I get after applying the patches to mapscript_i.c and php_mapscript.c:
> $ make
> mapscript_i.c: In function "layerObj_new":
> mapscript_i.c:462: error: request for member "index" in something not a structure or union
> make[1]: *** [mapscript_i.o] Error 1
> make[1]: Leaving directory `/usr/local/src/mapserver/cvs/mapserver/mapscript/php3'
> Sent: Wed 18-Apr-07 10:54
> I don't have an environment to build php yet, so I din't test them but
> the following two patches should fix your build.
> Please note that they don't add reference counting to php mapscript,
> they simply allow php mapscript to build on latest cvs.
> Let me know how it goes.
> Umberto
> > Thx. The patches seemed to work, but now
> > $ patch -p0 < rfc24-pathKralidis-mapogcsld.patch
> > patching file mapogcsld.c
> > $ patch -p0 < rfc24-pathKralidis-mapswf.patch
> > patching file mapswf.c
> > $ make
> > mapogcfilter.o
> > mapogcfilter.c: In function âFLTGetQueryResultsForNodeâ:
> > mapogcfilter.c:375: warning: assignment from incompatible pointer type
> > mapogcfilter.c:381: error: expected identifier before â)â token
> > mapogcfilter.c:559: error: expected â;â before â}â token
> > mapogcfilter.c:610: error: invalid storage class for function âaddResultâ
> > mapogcfilter.c: In function âFLTAddToLayerResultCacheâ:
> > mapogcfilter.c:659: warning: assignment from incompatible pointer type
> > mapogcfilter.c: In function âFLTArraysNotâ:
> > mapogcfilter.c:761: warning: assignment from incompatible pointer type
> > mapogcfilter.c: In function âFLTApplySimpleSQLFilterâ:
> > mapogcfilter.c:998: warning: assignment from incompatible pointer type
> > mapogcfilter.c:1047: error: expected identifier before â)â token
> > mapogcfilter.c:1070: error: expected â;â before â}â token
> > mapogcfilter.c:996: warning: unused variable âpszBufferâ
> > mapogcfilter.c:994: warning: unused variable âmsErrâ
> > mapogcfilter.c:988: warning: unused variable âszExpressionâ
> > mapogcfilter.c: In function âFLTApplyFilterToLayerâ:
> > mapogcfilter.c:1151: warning: initialization from incompatible pointer type
> > mapogcfilter.c: In function âFLTLayerApplyPlainFilterToLayerâ:
> > mapogcfilter.c:1196: warning: assignment from incompatible pointer type
> > mapogcfilter.c:3624: error: expected declaration or statement at end of input
> > mapogcfilter.c:348: warning: unused variable âdfCurrentToleranceâ
> > mapogcfilter.c:344: warning: unused variable âpanResultsâ
> > mapogcfilter.c:343: warning: unused variable âsProjTmpâ
> > mapogcfilter.c:342: warning: unused variable ânTokensâ
> > mapogcfilter.c:341: warning: unused variable âtokensâ
> > mapogcfilter.c:336: warning: unused variable âiâ
> > mapogcfilter.c:336: warning: unused variable ânEpsgTmpâ
> > make: *** [mapogcfilter.o] Error 1
> > ..so then I made changes to mapogcfilter.c:
> > $ cvs diff mapogcfilter.c
> > Index: mapogcfilter.c
> > RCS file: /data2/cvsroot/mapserver/mapogcfilter.c,v
> > retrieving revision 1.71
> > diff -r1.71 mapogcfilter.c
> > 381c381
> > < initClass(&(lp->class[0]->);
> > > initClass(&(lp->class[0]));
> > 408c408
> > < initClass(&(lp->class[1]->);
> > > initClass(&(lp->class[1]));
> > 1047c1047
> > ...and then receive the following error:
> > php_mapscript.c: In function âphp3_ms_map_getAllLayerNamesâ:
> > php_mapscript.c:3903: error: request for member ânameâ in something not a structure or union
> > make[1]: *** [php_mapscript.o] Error 1
> > $ make
> > php_mapscript.c: In function "php3_ms_map_getAllLayerNames":
> > Again, I have not committed anything as this looks like a bunch of wholesale changes.
> > ..Tom
> > From: UMN MapServer Developers List on behalf of Umberto Nicoletti
> > Sent: Wed 18-Apr-07 05:24
> > To: MAPSERVER-DEV at LISTS.UMN.EDU
> > Cc:
> > After applying the following two patches mapserver *compiles* in this
> > configuration.
> > ./configure --with-threads --without-pdf --without-tiff --with-gdal
> > --with-proj --with-geos --with-ming --with-ogr --with-wms --with-wcs
> > --with-sos -with-agg --with-wmsclient --with-wfsclient --with-eppl
> > I am on Ubuntu Feisty.
> > I cannot apply the patches today, since I am at a customer site
> > without cvs access.
> > Please report status so I can commit the changes asap.
> > Umberto
> > On 4/18/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> > > I'm working on fixing it...
> > > I'll make a patch available later today.
> > > Umberto
> > > On 4/17/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> > > > on FC6, using latest CVS, using:
> > > > $ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
> > > > ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
> > > > /gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
> > > > --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
> > > > /usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
> > > > src/agg/agg-2.5/
> > > > mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
> > > > mapswf.c:1326: error: expected â)â before â;â token
> > > > mapswf.c:1539: warning: assignment from incompatible pointer type
> > > > mapswf.c:1539: error: expected â;â before â}â token
> > > > mapswf.c:1266: warning: unused variable âfcâ
> > > > I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c. Checking HEAD shows numerous updates related to RFC 24. As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
> > > > ..Tom
