build error
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Apr 18 11:45:13 EDT 2007
I'll commit tomorrow, thanks
On 4/18/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
> With this change, the code builds.
> Umberto: if you want me to commit your patches, let me know and I will do so.
>         -----Original Message-----
>         From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
>         Sent: Wed 18-Apr-07 11:04
>         To: Kralidis,Tom [Burlington]
>         Cc: MAPSERVER-DEV at lists.umn.edu
>         Subject: Re: [UMN_MAPSERVER-DEV] build error
>         I hope that's the last error!
>         Change the line to read as:
>             map->layers[map->numlayers]->index = map->numlayers;
>         that is: change the dot before index to an arrow.
>         Umberto
>         > Thx.  Here's what I get after applying the patches to mapscript_i.c and php_mapscript.c:
>         > $ make
>         > mapscript_i.c: In function "layerObj_new":
>         > mapscript_i.c:462: error: request for member "index" in something not a structure or union
>         > make[1]: *** [mapscript_i.o] Error 1
>         > make[1]: Leaving directory `/usr/local/src/mapserver/cvs/mapserver/mapscript/php3'
>         >         Sent: Wed 18-Apr-07 10:54
>         >         I don't have an environment to build php yet, so I din't test them but
>         >         the following two patches should fix your build.
>         >         Please note that they don't add reference counting to php mapscript,
>         >         they simply allow php mapscript to build on latest cvs.
>         >         Let me know how it goes.
>         >         Umberto
>         >         > Thx.  The patches seemed to work, but now
>         >         > $ patch -p0 < rfc24-pathKralidis-mapogcsld.patch
>         >         > patching file mapogcsld.c
>         >         > $ patch -p0 < rfc24-pathKralidis-mapswf.patch
>         >         > patching file mapswf.c
>         >         > $ make
>         >         > mapogcfilter.o
>         >         > mapogcfilter.c: In function âFLTGetQueryResultsForNodeâ:
>         >         > mapogcfilter.c:375: warning: assignment from incompatible pointer type
>         >         > mapogcfilter.c:381: error: expected identifier before â)â token
>         >         > mapogcfilter.c:559: error: expected â;â before â}â token
>         >         > mapogcfilter.c:610: error: invalid storage class for function âaddResultâ
>         >         > mapogcfilter.c: In function âFLTAddToLayerResultCacheâ:
>         >         > mapogcfilter.c:659: warning: assignment from incompatible pointer type
>         >         > mapogcfilter.c: In function âFLTArraysNotâ:
>         >         > mapogcfilter.c:761: warning: assignment from incompatible pointer type
>         >         > mapogcfilter.c: In function âFLTApplySimpleSQLFilterâ:
>         >         > mapogcfilter.c:998: warning: assignment from incompatible pointer type
>         >         > mapogcfilter.c:1047: error: expected identifier before â)â token
>         >         > mapogcfilter.c:1070: error: expected â;â before â}â token
>         >         > mapogcfilter.c:996: warning: unused variable âpszBufferâ
>         >         > mapogcfilter.c:994: warning: unused variable âmsErrâ
>         >         > mapogcfilter.c:988: warning: unused variable âszExpressionâ
>         >         > mapogcfilter.c: In function âFLTApplyFilterToLayerâ:
>         >         > mapogcfilter.c:1151: warning: initialization from incompatible pointer type
>         >         > mapogcfilter.c: In function âFLTLayerApplyPlainFilterToLayerâ:
>         >         > mapogcfilter.c:1196: warning: assignment from incompatible pointer type
>         >         > mapogcfilter.c:3624: error: expected declaration or statement at end of input
>         >         > mapogcfilter.c:348: warning: unused variable âdfCurrentToleranceâ
>         >         > mapogcfilter.c:344: warning: unused variable âpanResultsâ
>         >         > mapogcfilter.c:343: warning: unused variable âsProjTmpâ
>         >         > mapogcfilter.c:342: warning: unused variable ânTokensâ
>         >         > mapogcfilter.c:341: warning: unused variable âtokensâ
>         >         > mapogcfilter.c:336: warning: unused variable âiâ
>         >         > mapogcfilter.c:336: warning: unused variable ânEpsgTmpâ
>         >         > make: *** [mapogcfilter.o] Error 1
>         >         > ..so then I made changes to mapogcfilter.c:
>         >         > $ cvs diff mapogcfilter.c
>         >         > Index: mapogcfilter.c
>         >         > RCS file: /data2/cvsroot/mapserver/mapogcfilter.c,v
>         >         > retrieving revision 1.71
>         >         > diff -r1.71 mapogcfilter.c
>         >         > 381c381
>         >         > <         initClass(&(lp->class[0]->);
>         >         > >         initClass(&(lp->class[0]));
>         >         > 408c408
>         >         > <                     initClass(&(lp->class[1]->);
>         >         > >                     initClass(&(lp->class[1]));
>         >         > 1047c1047
>         >         > ...and then receive the following error:
>         >         > php_mapscript.c: In function âphp3_ms_map_getAllLayerNamesâ:
>         >         > php_mapscript.c:3903: error: request for member ânameâ in something not a structure or union
>         >         > make[1]: *** [php_mapscript.o] Error 1
>         >         > $ make
>         >         > php_mapscript.c: In function "php3_ms_map_getAllLayerNames":
>         >         > Again, I have not committed anything as this looks like a bunch of wholesale changes.
>         >         > ..Tom
>         >         >         From: UMN MapServer Developers List on behalf of Umberto Nicoletti
>         >         >         Sent: Wed 18-Apr-07 05:24
>         >         >         To: MAPSERVER-DEV at LISTS.UMN.EDU
>         >         >         Cc:
>         >         >         After applying the following two patches mapserver *compiles* in this
>         >         >         configuration.
>         >         >         ./configure --with-threads --without-pdf --without-tiff --with-gdal
>         >         >         --with-proj --with-geos --with-ming --with-ogr --with-wms --with-wcs
>         >         >         --with-sos -with-agg --with-wmsclient --with-wfsclient --with-eppl
>         >         >         I am on Ubuntu Feisty.
>         >         >         I cannot apply the patches today, since I am at a customer site
>         >         >         without cvs access.
>         >         >         Please report status so I can commit the changes asap.
>         >         >         Umberto
>         >         >         On 4/18/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
>         >         >         > I'm working on fixing it...
>         >         >         > I'll make a patch available later today.
>         >         >         > Umberto
>         >         >         > On 4/17/07, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca> wrote:
>         >         >         > > on FC6, using latest CVS, using:
>         >         >         > > $ ./configure --enable-debug --with-freetype=/usr/local/bin/freetype-config --with-zlib=/usr/local/ --with-png=/usr/local/ --w
>         >         >         > > ith-jpeg=/usr/local/ --with-gd=/usr/local --with-pdf=/usr/local --with-eppl --with-proj=/usr/local --with-ogr=/usr/local/bin
>         >         >         > > /gdal-config --with-gdal=/usr/local/bin/gdal-config --without-tiff --with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs
>         >         >         > > --with-wcs --with-wmsclient --with-wfsclient --with-curl-config=/usr/local/bin/curl-config --with-xpm=/usr/local --with-php=
>         >         >         > > /usr/local/src/php/php-5.2.1 --with-ming=/usr/local --with-sos --with-geos=/usr/local/bin/geos-config --with-agg=/usr/local/
>         >         >         > > src/agg/agg-2.5/
>         >         >         > > mapswf.c: In function âmsDrawMarkerSymbolSWFâ:
>         >         >         > > mapswf.c:1326: error: expected â)â before â;â token
>         >         >         > > mapswf.c:1539: warning: assignment from incompatible pointer type
>         >         >         > > mapswf.c:1539: error: expected â;â before â}â token
>         >         >         > > mapswf.c:1266: warning: unused variable âfcâ
>         >         >         > > I fixed (but did not commit) this in mapswf.c, but then I got errors in mapogcfilter.c.  Checking HEAD shows numerous updates related to RFC 24.  As this looks like a huge bunch of changes, I did not touch anything, for maybe Umberto to check first.
>         >         >         > > ..Tom
