build error
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Wed Apr 18 12:07:57 EDT 2007
You get the grand prize for spotting it! ;-)
http://mapserver.gis.umn.edu/docs/howto/phpmapscript-install
says php5 support is in development, although the doc is quite old.
Umberto
On 4/18/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Umberto Nicoletti wrote:
> > I was able to build php mapscript with the changes I have sent you. If
> > I try to load php_mapscript I get this error:
> > --------------/BEGIN
> > <HTML>
> > <BODY>
> > Warning: dl(): Unable to load dynamic library
> > '/usr/lib/php5/20060613+lfs/php_mapscript.so' -
> > /usr/lib/php5/20060613+lfs/php_mapscript.so: cannot open shared
> > object file: Too many levels of symbolic links in
> > /home/unicoletti/Workspace/scratch/mapserver/mapscript/php3/test.php
> > on line 11
> PHP5 is well supported.
> The error message "Too many levels of symbolic links" suggests... well,
> it suggests what it says, that
> /usr/lib/php5/20060613+lfs/php_mapscript.so may be a recursive symlink
> or something like that.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
