sde getFeature on DATE fields
Hallgren Johan E jhhal at WMDATA.COM
Wed Apr 25 05:15:49 EDT 2007
Hello
I have found something as I see as a BUG.
I use getFeature in MapScript on a layer with date-fields.
It does only appear on SDE layers and it's the row below that crash as
soon as I have a date-field in the table.
shapeObj oShapeObj =
oLayerObj.getFeature(oResultCacheMemberObj.shapeindex,
oResultCacheMemberObj.tileindex);
Now I found the problem.
In mapsde.c I changed the line:
#define MS_SDE_TIMEFMT "%T %m/%d/%Y"
to
#define MS_SDE_TIMEFMT "%H:%M:%S %m/%d/%Y"
And then the problem was gone.
I use Visuals Studio 2005, and I can only guess that the %T is not
supported in that compiler.
I hope this can be changed in the mapsde.c-file.
Best Regards
Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
Sent: den 11 april 2007 17:43
To: Hallgren Johan E
Subject: Re: [UMN_MAPSERVER-DEV] sde getFeature on DATE fields
Johan,
With current CVS, I am able to render dates as labels from an SDE
server.  The mapsde.c code in HEAD has seen a significant reworking
recently, although there is one pretty serious bug outstanding that I
am expecting to get to
<http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2067>.  You should
be able to drop in a copy of CVS HEAD's mapsde.c into your 4.10.1
distribution and recompile if you wish to test.
Howard
At 04:18 AM 4/11/2007, you wrote:
>Hello
>I have a problem when using getFeature on date-fields.
>The row will crash as soon as I have a date-field in the table. It's
>only related to SDE layers.
>I have seen the problem in version 4.10.1 as well as in snapshots after
that.
>Any solution?
>/Johan
>Johan Hallgren
>Pelle Bergs backe 3
>johan.e.hallgren<BLOCKED::mailto:johan.e.hallgren at wmdata.com>@wmdata.co
m
><BLOCKED::/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>http://www.w
mdata.se
