SV: Build with debug
Hallgren Johan E
jhhal at WMDATA.COM
Fri Apr 27 00:44:16 EDT 2007
Hello Tamas
These are the settins I use, do you mean that this it should be correct? I have DEBUG ON on both root tag and on the specifc layer. Could the output be somewhere where I dont't see it? I use Mapscript in Visual studio, and I expected to see the ouput at the Debug/output window.
# Optimized, with using MSVCRT.
OPTFLAGS = /nologo /Ox /MD $(WARNING_LEVEL) $(DEBUG) /EHsc
# Uncomment the following to link mapserv.exe with a dll. In almost
# all cases you will want to do this.
DLLBUILD = 1
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=/W3
# Debugging Options
ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
# Set the linker debug option
# LDEBUG=/debug
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
# DEBUG=/DDEBUG
Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com <mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se <https://webaccess.wmdata.com/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
Från: Tamas Szekeres [mailto:szekerest at gmail.com]
Skickat: to 2007-04-26 19:21
Till: Hallgren Johan E
Kopia: MAPSERVER-DEV at lists.umn.edu
Ämne: Re: Build with debug
Johan,
You might have to compile with ENABLE_STDERR_DEBUG and use "DEBUG ON"
in your map configuration.
Verbose output is generated and sent to the standard error output (STDERR).
Best regards,
Tamas
2007/4/26, Hallgren Johan E <jhhal at wmdata.com>:
> Hello
> I tries to build MapServer so I can see msDebug()-output. I expect to see
> the output in the VS-output window, or in the console running the program
> but I don't. Do I have to change some compiler directives that I have
> missed?
> /Johan
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> http://www.wmdata.se <http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070427/cc528d60/attachment.html
