Loading a mapfile from a string...
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Apr 27 00:46:21 EDT 2007
Only one comment (and positive at that) so... this has been commited. One caveat is that to avoid leaking memory yylex_destroy is being used to clean things up. Apparently this is available in newer versions of flex. May actually be there in old versions but only if a reentrant scanner is being built. Presents a small problem. We can control the distributions by using a newish version of flex when building things for users. Requiring developers to use version x.x.x (I'm at 2.5.31) doesn't seem to big a hardship. Thoughts?
Steve
>>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 04/17/07 11:28 PM >>>
Hi Folks: I've been screwing around with getting mapserver to ingest a mapfile stored in a string buffer rather than a file. In theory you could build up a configuration from text snippets or database output rather than manipulating objects directly. The code could almost do this in the past but needed some reorganization to re-use as much as possible. The result is a new function called msLoadMapFromString. I took the opportunity to fix some naming wierdness in mapfile.c and to clean up lexer initialization a bit. In otherwords I'm sitting on a fair number of minor changes to mapfile.c and maplexer.l (with a few other small edits elsewhere). Is this a big enough deal to warrant a RFC or can I just commit?
Steve
BTW A sample perl snippet might look like (mapscript integration isn't part of these changes other than exposing the function):
$buffer = "MAP ... END";
$map = $mapscript::msLoadMapFromString($buffer, undef); # takes the buffer and an optional directory (location of symbols...)
