MapServer 5.0.0-beta2 released
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Aug 1 15:44:32 EDT 2007
Hi everyone,
MapServer 5.0.0-beta2 has just been released. The source package and
links to binary distributions are available at:
http://mapserver.gis.umn.edu/download/beta
The list of changes/fixes since beta1 is included at the bottom of this
email.
As was mentioned before, we plan to have one beta per week until the
final release of MapServer 5.0 which is planned for the week of
September 12, 2007. More details can be found in the 5.0 release plan at
http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_0/release_plan/
Daniel
Version 5.0.0-beta2 (2007-08-01)
- Oracle Spatial: Fixed some issues related with the maporaclespatial.c
source code: warnings with calls in gcc 4.x versions (#1845), gtype
translation error, generating memory problem (#2056), problems with items
allocation (#1961 and #1736), and some memory-leaks errors (#1662).
- AGG: Fixed a significant number of rendering issues including
conflicts with
OPACITY ALPHA and ANTIALIAS TRUE settings w/regards to polygon fills.
Fixed
ellipse and vector markers. Fixed AGG/GD alpha channel conflicts by
writing
conversion to/from functions. (#2191-partial, #2173, #2177)
- SOS: Turn layer off if eventTime is not in the sos_offering_timeextent
(#2154)
- WFS: Correct bugs related to query by featureid support (#2102)
- WMS: Add svg as a supported format for GetMap request (#1347)
- WMS: Correct WMS time overriding Filter paramter (#1261)
- Fix problem with LUT scaling ranges with explicit value for 255 (#2167).
- WCS: Fixed resampling/reprojecting for tileindex datasets (#2180)
- Fixed formatting of configure --help (#2182)
- Fixed AGG configure option to use 'test -f' instead of 'test -e' which
doesn't work on Solaris (#2183)
- Fixed mapwms.c to support selecting AGG/ outputformats via FORMAT=.
- Removed unused styleObj.isachild member (#2169)
