SDE 9.2 - Libs
Huey Brantley huey.brantley at VANDERBILT.EDU
Fri Aug 3 09:26:42 EDT 2007
Howard is correct. I used options, had to use the sdk and not the gis
install.
--with-sde=/u01/app/arcgis92sdk/sdeexe92/
--with-sde-version=92
I also want to point out that if your 9.2 is a new install or if you
create any new FC's after upgrading, you will probably have trouble
labeling using VARCHAR column types.  ESRI changed the default types to
support NVARCHAR (unicode).  MapServer won't be able to use this.  You
will have to override ESRI's defaults by adding:
UNICODE_STRING FALSE
In the defaults section of dbtune.sde.
-hb
On Thu, 2007-08-02 at 09:50 -0500, Howard Butler wrote:
> Johannes,
> I believe you need to use --with-sde=[PATH]/sdeexe92 --with-sde-
> version=92
> You must have the ArcSDE Client SDK installed, which has the include
> files and libraries to link against.
> ESRI changed their library layout in 9.2, and if I recall correctly,
> MapServer's configure logic is able to handle it when given --with-
> sde-version=92.
> Howard
> On Aug 2, 2007, at 8:15 AM, Hr. Johannes Loose wrote:
> > Hello List
> > I am trying to compile mapserver 4.10.2  with ArcSDE 9.2 support.
> > Compiling has worked fine for SDE 9.1 using the sdeexe91 tree
> > (including sdetype.h /
> > libsde91.a / libsde91.so). The sdeexe92 tree does NOT contain the
> > files sdetype.h,
> > libsde92.a, libsde92.so. Hence the configure script is not able to
> > find that files and prints out
> > the related error. The flags i used for the configure script are: --
> > with-sde-version=92 --with-
> > sderaster --with-sde=[PATH]/sdeexe92/lib
> > How can this be fixed?
> > Thanks in advance for any helping reply :-)
> > Johannes Loose
