mapserver 5.0.0-beta2 and AGG detection in configure.in
thomas bonfort
thomas.bonfort at GMAIL.COM
Sat Aug 4 11:38:47 EDT 2007
for the time being we don't use it, and I don't plan on using it. for
polygon fills there's an AGG function.
from antigrain.com:
In *AGG* you can get the same visual result using Scanline Boolean Algebra.
It operates with scanline shapes and in average works 5-10 times faster than
GPC
On 8/4/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Even Rouault wrote:
> > Currently in configure.in, if you specifiy "--with-agg" or
> "--with-agg=yes"
> > there is a check for gpc_polygon_clip to enable AGG build.
> > AC_CHECK_LIB(agg, gpc_polygon_clip, AGG_ENABLED=-DUSE_AGG,,,)
> > However, GPC has a non free licence ("free for non-commercial use"). See
> > http://www.antigrain.com/license/index.html. So, my build of AGG doesn't
> > include GPC.
> > I've removed the check for gpc_polygon_clip in configure.in and
> mapserver
> > 5.0.0-beta2 builds fine.
> Even,
> I have also seen that many of the free software distributions are not
> including GPC support in AGG for obvious reasons. So if we don't need
> this
> function it would seem to be a bad one to check for. I have taken the
> liberty of creating a trac ticket for this issue. I'd encourage you to
> add yourself as a cc: for it.
> http://trac.osgeo.org/mapserver/ticket/2204
> I also created a new svn-trunk "version" in trac that we can use when
> reporting bugs specifically in the current development trunk.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070804/fd8a92d7/attachment.html
