AGG update and possible breakage
thomas bonfort
thomas.bonfort at GMAIL.COM
Mon Aug 6 09:18:55 EDT 2007
have been looking more into this...
ubuntu, debian, redhat, mandrake and probably others all bundle their
libagg-dev or equivalent with the .h in the agg include directory and with
libaggfontfreetype.so in lib .
things go badder if you try to compile using the source directory of agg as
your --with-agg parameter, as libaggfontfreetype.o is not compiled by
default, and agg_font_freetype.h is not in the include directory.
for the autoconf knowledgeable:
would their be a way of checking if agg_font_freetype.h and
libaggfontfreetype.so are in the default paths,
and then setting AGG_LIB=-lagg -laggfontfreetype,
and if not compile or have the user compile
$AGG_DIR/font_freetype/agg_font_freetype.cpp, and then have
AGG_INC+=AGG_DIR/font_freetype and
AGG_LIB=AGG_DIR/font_freetype/agg_font_freetype.o -lagg
I think falling back to GD would be a pity as it's relatively easy to set
this up
tb
On 8/6/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Should this be added as a configure option? ie: use it if agg is
> selected and the libaggfontfreetype or the .h is included in the
> distribution, otherwise fall back on GD by using #ifdef's.
> -Steve
> thomas bonfort wrote:
> > update:
> > ubuntu's distribution of agg includes the header file, and all goes well
> > if I add -laggfontfreetype to the LIBS
> > On 8/6/07, *thomas bonfort* <thomas.bonfort at gmail.com
> > <mailto:thomas.bonfort at gmail.com>> wrote:
> > hi devs
> > AGG rendering is now mostly complete, including font rendering.
> > the agg source distribution includes a freetype font manager that is
> > not built by default and not included in the main source/include
> > directories, but in the font_freetype subdir. For font rendering to
> > work, I've pulled agg_font_freetype.cpp and .h into the mapserver
> > directory, as there are high chances that distribution releases of
> > AGG will not include the agg_font_freetype.o in their libagg or
> > agg_font_freetype.h in their headers.
> > After discussing this with frank, due to the non negligeable risks
> > of breaking things, I'll be waiting for your feedback/comments/etc..
> > on this before commiting all this.
> > thomas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070806/4b588324/attachment.html
