AGG update and possible breakage
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Aug 6 10:47:18 EDT 2007
Thomas,
I use the agg source directory because it was not possible (or easy) to
install a distribution on my system (Debian Sarge x64), butusing the
source tarball was trivial. I think we need to get some ./configure
support on this to check and report issues with the using the source
tarball that is not installed on the system like:
./configure \
--enable-ignore-missing-data \
--enable-debug \
--with-httpd=/usr/sbin/apache \
--with-proj=/usr \
--with-agg=/u/software/agg-2.5 \
--with-gd \
--with-gdal \
--with-freetype \
--with-postgis \
--without-tiff \
--with-wmsclient \
--with-ogr \
--with-wfs \
But, I have not been able to get the autoconf and automake tools to work
with AGG and have not been able to figure out how to build AGG with the
freetype support :/
I'm signing up to the AGG list to ask about these issues.
-Steve W
thomas bonfort wrote:
> have been looking more into this...
> ubuntu, debian, redhat, mandrake and probably others all bundle their
> libagg-dev or equivalent with the .h in the agg include directory and
> with libaggfontfreetype.so in lib .
> things go badder if you try to compile using the source directory of agg
> as your --with-agg parameter, as libaggfontfreetype.o is not compiled by
> default, and agg_font_freetype.h is not in the include directory.
> for the autoconf knowledgeable:
> would their be a way of checking if agg_font_freetype.h and
> libaggfontfreetype.so are in the default paths,
> and then setting AGG_LIB=-lagg -laggfontfreetype,
> and if not compile or have the user compile
> $AGG_DIR/font_freetype/agg_font_freetype.cpp, and then have
> AGG_INC+=AGG_DIR/font_freetype and
> AGG_LIB=AGG_DIR/font_freetype/agg_font_freetype.o -lagg
> I think falling back to GD would be a pity as it's relatively easy to
> set this up
> tb
> On 8/6/07, *Stephen Woodbridge* < woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>> wrote:
> Should this be added as a configure option? ie: use it if agg is
> selected and the libaggfontfreetype or the .h is included in the
> distribution, otherwise fall back on GD by using #ifdef's.
> -Steve
> > update:
> > ubuntu's distribution of agg includes the header file, and all
> goes well
> > if I add -laggfontfreetype to the LIBS
> > On 8/6/07, *thomas bonfort* <thomas.bonfort at gmail.com
> <mailto:thomas.bonfort at gmail.com>
> > <mailto: thomas.bonfort at gmail.com
> <mailto:thomas.bonfort at gmail.com>>> wrote:
> > hi devs
> > AGG rendering is now mostly complete, including font rendering.
> > the agg source distribution includes a freetype font manager
> that is
> > not built by default and not included in the main source/include
> > directories, but in the font_freetype subdir. For font
> rendering to
> > work, I've pulled agg_font_freetype.cpp and .h into the
> mapserver
> > directory, as there are high chances that distribution
> releases of
> > AGG will not include the agg_font_freetype.o in their libagg or
> > agg_font_freetype.h in their headers.
> > After discussing this with frank, due to the non negligeable
> risks
> > of breaking things, I'll be waiting for your
> feedback/comments/etc..
> > on this before commiting all this.
> > thomas
