MapServer 5.0.0-beta2 released
Eduardo Patto Kanegae
eduardo.kanegae at INFLOR.COM.BR
Tue Aug 7 07:37:38 EDT 2007
Just to notice,
I downloaded latest MS4W yesterday, copied sde91.dll, sg91.dll and
pe91.dll to /ms4w/apache/cgi-bin/
And then copied /ms4w/Apache/cgi-bin/ignored-libmap/sde9.1/libmap.dll to
but when I tried to run "mapserv.exe -v" I got a windows error message
like this:
** Could not found the entrypoint for msDebugInitFromEnv at libmap.dll **
best regards,
Eduardo
INFLOR Consultoria e Sistemas Ltda.
Consultor GIS
Tel: +55(27)2122-0888
Cel: +55(27)8155-2990
Fax: +55(27)2122-0861
eduardo.kanegae at inflor.com.br <mailto:eduardo.kanegae at inflor.com.br>
www.inflor.com.br <http://www.inflor.com.br>
Daniel Morissette escreveu:
> Hi everyone,
> MapServer 5.0.0-beta2 has just been released. The source package and
> links to binary distributions are available at:
> http://mapserver.gis.umn.edu/download/beta
> The list of changes/fixes since beta1 is included at the bottom of
> this email.
> As was mentioned before, we plan to have one beta per week until the
> final release of MapServer 5.0 which is planned for the week of
> September 12, 2007. More details can be found in the 5.0 release plan
> at
> http://mapserver.gis.umn.edu/development/release_plans/mapserver_5_0/release_plan/
> Daniel
> Version 5.0.0-beta2 (2007-08-01)
> - Oracle Spatial: Fixed some issues related with the maporaclespatial.c
> source code: warnings with calls in gcc 4.x versions (#1845), gtype
> translation error, generating memory problem (#2056), problems with
> items
> allocation (#1961 and #1736), and some memory-leaks errors (#1662).
> - AGG: Fixed a significant number of rendering issues including
> conflicts with
> OPACITY ALPHA and ANTIALIAS TRUE settings w/regards to polygon
> fills. Fixed
> ellipse and vector markers. Fixed AGG/GD alpha channel conflicts by
> writing
> conversion to/from functions. (#2191-partial, #2173, #2177)
> - SOS: Turn layer off if eventTime is not in the sos_offering_timeextent
> (#2154)
> - WFS: Correct bugs related to query by featureid support (#2102)
> - WMS: Add svg as a supported format for GetMap request (#1347)
> - WMS: Correct WMS time overriding Filter paramter (#1261)
> - Fix problem with LUT scaling ranges with explicit value for 255
> (#2167).
> - WCS: Fixed resampling/reprojecting for tileindex datasets (#2180)
> - Fixed formatting of configure --help (#2182)
> - Fixed AGG configure option to use 'test -f' instead of 'test -e' which
> doesn't work on Solaris (#2183)
> - Fixed mapwms.c to support selecting AGG/ outputformats via FORMAT=.
> - Removed unused styleObj.isachild member (#2169)
