beta3 issues
Normand Savard
nsavard at MAPGEARS.COM
Thu Aug 9 11:05:22 EDT 2007
Mike Leahy wrote:
>On Wed, 8 Aug 2007 23:04:37 -0400, Daniel Morissette
><dmorissette at MAPGEARS.COM> wrote:
>>It crashes with any of the Chameleon samples? It's possible that the
>>sample mapfiles need upgrading, but that should not cause a seg fault.
>>I'll have to try to reproduce that one.
>Good question...I just double-checked, and it works for the samples listed
>below, while the rest choke:
>Sample using simple images for buttons
>Sample using multi-state buttons
>Sample using multi-state buttons generated by buttonizer
>Sample using XML Theme Legend
>Basic Sample using the JSAPI mode
>So I would guess that the problem is cause by one or more functions used by
>widgets implemented in the other samples. If there's more I can do to
>narrow this down, let me know.
>Regards,
>Mike
Mike,
I reproduced the segfault with some of the Chameleon samples and I
opened the ticket #2218 to track this issue. If you want to put you in
cc to be aware of the new development on this issue.
Norm
