Motion: include AGG freetype (2.4 version) in MapServer
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Aug 13 14:00:59 EDT 2007
Howard Butler wrote:
> All,
> I've come around to thinking that the only way we can limit the
> configuration/building issues we are about to inflict on our users with
> AGG is to include the freetype stuff in MapServer's source. It seems
> many of the distros are treating the AGG freetype inconsistently. Just
> building AGG because of its spartan build setup is quite a chore.
> Hacking makefiles, compile targets, and link lines to get what is needed
> is just too much.
> I propose we take the GDAL "thirdparty" approach and put the AGG
> freetype stuff in ./thirdparty/agg and update MapServer's configure/make
> system to always use that. We have done something similar in the past
> with GD, right? If so, this approach would not be unprecedented.
> Howard
Howard,
I am somewhat inclined to agree with you, but I think this will require
a smarter configure script. For example you would need to check if
agg_font_freetype were built into the distro or not before we arbitrary
build and add it a second time.
I also think some quick check to see if there are difference between AGG
2.4 and 2.5 APIs exist, because a user might have downloaded either of
these. I don't think this will be an issue because by chance and lack of
knowing better, I downloaded 2.5 instead of 2.4.
-Steve
