Motion: include AGG freetype (2.4 version) in MapServer
Howard Butler
hobu.inc at GMAIL.COM
Mon Aug 13 14:38:37 EDT 2007
On Aug 13, 2007, at 1:02 PM, Sean Gillies wrote:
> Howard Butler wrote:
>> All,
>> I've come around to thinking that the only way we can limit the
>> configuration/building issues we are about to inflict on our
>> users with AGG is to include the freetype stuff in MapServer's
>> source. It seems many of the distros are treating the AGG
>> freetype inconsistently. Just building AGG because of its
>> spartan build setup is quite a chore. Hacking makefiles, compile
>> targets, and link lines to get what is needed is just too much.
>> I propose we take the GDAL "thirdparty" approach and put the AGG
>> freetype stuff in ./thirdparty/agg and update MapServer's
>> configure/ make system to always use that. We have done something
>> similar in the past with GD, right? If so, this approach would
>> not be unprecedented.
>> Howard
> I disagree. One of the tenets of Open Source is that people
> collaborate on software and fork only as a last resort. Why not
> contribute improvements to AntiGrain? I thought I read that the
> author was going to grant a GPL exception explicitly to MapServer.
Someone please correct me if I am wrong, but my reasoning for this
motion is as follows:
- AGG will never be mainlining the freetype stuff because it
doesn't want it as a default dependency
- The AGG author doesn't want to use autoconf/libtool, so patches
that we might submit to make building things with options more easy
are likely to rejected.
- AGG's license split (and ambiguity with respect to MapServer
specifically) and MapServer's usage where GPL isn't appropriate means
we'll have a not insignificant number of people continuing to use AGG
2.4, where patches like this, even if accepted, would not apply to them.
- It is a lesser evil (in terms of work required and badwill
generated) to just maintain a small copy of the freetype stuff than
to fork *all* of AGG at 2.4. Some other group may yet do this (I
have no direct knowledge). It almost happened a number of times with
libgd before Boutell let PHP pick it up.
Howard
