thread safety and OGR
Tamas Szekeres szekerest at GMAIL.COM
Sun Aug 19 19:39:33 EDT 2007
Frank,
Currently Java has a threadtest implemented in the mapserver tree and
I'm planning to write such tool also for the C# interface as the part
of the normal testing process.
Best regards,
2007/8/20, Frank Warmerdam <warmerdam at pobox.com>:
> Tamas Szekeres wrote:
> > Frank,
> > I'm +0 on this issue since it is a symptomatic treatment but we should
> > also discover the particular reason of the issue. We should also
> > aspire to support the independent execution of the multiple threads as
> > much as we can.
> > As far as I remember the GetFieldAsString problem of OGR have been
> > treated as of RFC-6 as a "side effect".
> > We might want to ask the client for testing with the latest OGR. It
> > would be also practical to see whether your temporary fix really
> > solves the client's problem or not. If yes I would be interested in
> > tracking down the root of the problem at the OGR level.
> Tamas,
> My client is apparently using C# mapscript, and will be providing me
> with details to reproduce the problem and verify it's correction.  I'll
> also be preparing some sort of "multi-threaded heavy load" tester to help
> verify correction operation.
> Co-incidentally, I also have a contract to implement some degree of
> thread safety within OGR (for GDAL/OGR 1.5.0) though that doesn't
> offer any guarantee that every driver will be threadsafe.  So some work on
> the root of the problem is also underway though for that there are always
> "conditions" (only verified for some drivers, only safe if no two threads
> use the same OGRLayer, etc).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
