Issue with 5.0 beta 5 (MS4W 2.2.6)
John Cole
john.cole at UAI.COM
Thu Aug 23 14:49:07 EDT 2007
Thanks Daniel,
The libmysql.dll fix worked. Now I can compare 4 vs 5 on performance
(I'll start another thread on that).
And I got my debugging info out.
Thanks,
John
Daniel Morissette-2 wrote:
> John Cole wrote:
>> I'm using the freshly minted MS4W 2.2.6, which I believe has MS5 Beta 5
>> and
>> have the following issue.
>> Maps returning are being drawn very quickly, but the browser (FF2 or IE7)
>> are holding the connections open for 5+ seconds on each map request.
>> This
>> quickly adds up when tiling from MS.
>> Looking at a mode=browse page, the following error is appearing when the
>> connection is finally released:
>> Error in my_thread_global_end(): 1 threads didn't exit
> It seems that PHP 5.2.2 and 5.2.3 have a broken libmysql.dll, see:
> http://bugzilla.maptools.org/show_bug.cgi?id=1730
> ... and I also read elsewhere that using the libmysql.dll from MS4W
> 2.2.3 could solve the issue.
>> When debugging is on, I'm not getting any timing or layer stats anymore
>> either.
> This may be related to RFC-28 changes in 5.0. The short answer is that
> with 5.0 you need to set in your mapfile:
> CONFIG MS_ERRORFILE "stderr"
> ... and for the full story see
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-28
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
View this message in context: http://www.nabble.com/Issue-with-5.0-beta-5-%28MS4W-2.2.6%29-tf4317708.html#a12299653
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
